Old July 31, 2008, 07:50 AM
werty316's Avatar
If the SSC is only $10 more I would opt for it since there is a good chance it'll have more overclocking headroom.
If you can see Chuck Norris, he can see you. If you can't see Chuck Norris you may be only seconds away from death.
Old July 31, 2008, 08:30 AM
MpG's Avatar
MpG MpG is offline
Yeah, I misread the pricing. For $10 difference, you might as well grab the slightly faster card.
Old July 31, 2008, 03:56 PM
CTA's Avatar
CTA CTA is offline
alright... good!
thank you very much for sharing your experience or even knowledge... very appreciated...thank for good members at good forums... i will live here for a while...
cheers
al
