-   -   Ati 4870 Temp (http://www.hardwarecanucks.com/forum/video-cards/8970-ati-4870-temp.html)
Computergeek July 30, 2008 02:25 PM
Ati 4870 Temp
Are these temps ok...or should i be worried?
http://gpuz.techpowerup.com/08/07/30/fwt.png
Cheator July 30, 2008 02:29 PM
What is it under load?
Computergeek July 30, 2008 02:31 PM
nope thats just idle
misterlarry July 30, 2008 02:38 PM
If that's idle temp then I would hate to see load temps. :shok: I'm not familiar with the temp range for the 4870 but my 8800 GTS idles at about 33-34 and is loaded at 47-48 degrees.
Infiniti July 30, 2008 02:39 PM
Wow, is that with stock cooling?
Anyways, I think your 4870 might be defective. Most video cards should run at 50-60C idle. Correct me if I'm wrong though.
Computergeek July 30, 2008 02:43 PM
The crazy thing is it run just fine i see no problems just thought i would check it out.....i read alot that these run hot
is there a another program i can use to double check thesre temps
magictorch July 30, 2008 02:58 PM
Youll have to make a profile in CCC and run the fan hack. It is the only way right now to get acceptable temps. They set the fan to 20% for some reason and it gets too hot. 35% is quiet and will bring it down about 25oc! The fanhack is safe to use.
Computergeek July 30, 2008 03:09 PM
how do i do this good sir?
SugarJ July 30, 2008 03:18 PM
Follow this thread:
http://www.hardwarecanucks.com/forum...ed-4800-a.html
Good luck.
magictorch July 30, 2008 03:21 PM
Theres a link here. To make it easier make sure you can "see" all files and folders. I just searched using "search" for the profile file I created in CCC and hotlinked it in another folder for easy access. You only need to edit a couple numbers/words.
