Old July 30, 2008, 03:31 PM
Computergeek's Avatar
but the fan noise is way different too...before i couldn't hear my GPU now thats all i can hear
Old July 30, 2008, 03:40 PM
magictorch's Avatar
At 35%? I cant hear mine but then again Ive got a fairly noisy 92mm fan as an exhaust.
What kind of noise is it? if its a high pitched or electronic whirring noise try improving the ventilation to the underside of the card and MB and the power regulators. My card was noisy at any fan speed before pointing a fan at the MOSFETs on the board.
Old July 30, 2008, 03:44 PM
misterlarry's Avatar
Is the Arctic Cooling Accelero compatible with the 4870? Is anyone running this combo?
Asrock Z68 Extreme3 Gen3 - Intel i5 2550K @ 3.4 GHz - Corsair H80 CPU Cooler- 4x4 GB G.Skill Ares DDR3 1600 - EVGA GTX560 Ti
1x120 GB Mushkin Chronos Enhanced SSD - 1x500 GB Seagate Hybrid Momentus - 2x500 GB Seagate Barracuda 7200.11 - Pioneer DVR-212D - Antec P182 - Corsair TX650 - 22" Hanns-G - Windows 7 Pro 64 SP1
The world is your oyster. Shuck away my friend, shuck away!
Old July 30, 2008, 03:48 PM
magictorch's Avatar
Ive heard of people using the accelero but one guy took an IR reading and found it did a bad job of keeping the RAM and MOSFETS cool.
Old July 30, 2008, 03:57 PM
I was able to move my fan speed to 30C% and still get the same results....48C
Old July 30, 2008, 04:13 PM
CanadaRox's Avatar
I'm going to be testing a modded BIOS file (based on the ASUS TOP 4870) which gives you a higher overclock limit in CCC as well as a more effective fan profile. It uses the stock clocks instead of the pre-overclocked ASUS ones so it should work on any 4870. I've already uploaded it to another thread, but I've yet to test it, so use at your own risk. Here is the thread: Asus 4870 Top Bios
Project: Black and White
Old July 31, 2008, 11:54 AM
chrisk's Avatar
Folding Captain
Let us know how the modded bios works for you. I have been using the profile hack to get my 4870 temps down but would prefer a more elegant solution.
Fold for team #54196
Old July 31, 2008, 12:05 PM
Originally Posted by misterlarry View Post
If that's idle temp then I would hate to see load temps. I'm not familiar with the temp range for the 4870 but my 8800 GTS idles at about 33-34 and is loaded at 47-48 degrees.
Mine idles about 79*C (same as his), hits 87*C at full load ... Stock cooling ...
The temperature doesn't fluctuate much, but it's still weird to see ~80*C as an idle temp ..
  #19 (permalink)
Old July 31, 2008, 12:12 PM
CanadaRox's Avatar
I couldn't have the default clocks and higher CCC limit, but I was able to have default clocks, the regular 790MHz limit in CCC and the better fan profile. I'll upload the BIOS here, refer to the other thread on how to get them installed.
  #20 (permalink)
Old July 31, 2008, 02:10 PM
Default Reply
When it comes to the VRM cooling the Accelero struggles. But if you want another good aftermarket cooler you can consider the Thermalright HR-03 GT. Probably the best cooler for the HD4870. SKY tested the Thermalright and it dropped temps almost 50%.
LINK:Palit Radeon HD4870 512MB Graphics Card Review
