<~----> FREE 3D Stress Test Program? - Hardware Canucks
Old July 29, 2008, 10:39 AM
Default FREE 3D Stress Test Program?
Just like the topic says does anyone know of a GOOD free stress test program? I wanna test this evga gtx260. Thanks in advance for the help.
p.s. sorry if this has been posted before.
Old July 29, 2008, 10:53 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
As in stability testing? ATITool is the best free one or you could do a google search for the Nvidia Geoforms demo.
Old July 29, 2008, 10:58 AM
Yah stability testing is what i am looking for. Something that can simulate playing a high graphics game for a few hours.
Thanks for the info SKYMTL.
Old July 29, 2008, 11:23 AM
vinister's Avatar
ryhbtl, or, rhyblt, rhstbl, something along those lines. HDR demo of some kind. It will stress multi-gpu's in crossfire (in full screen only). You can also run as many instances as you like at once.
Mobo: DFI 790X-M2R
Proc: AMD PHENOM X3 720
Ram: OCZ Platinum 2X 2GB @ 1066
VIDEO: 3 x Visiontek HD3870
Old July 29, 2008, 11:29 AM
Eldonko's Avatar
Hardware Canucks Reviewer
I second ati tool. It is a good pre test before firing up 3dmark.
Old July 29, 2008, 11:34 AM
So basicly just let that run for a few hours?
Old July 29, 2008, 11:44 AM
Im a lil confused with ATITools. I must be missing something... is it basicly just for upping the clock speed and such? Other then that cube floating around i cant seem to find any options to test with it.
Old July 29, 2008, 11:56 AM
SKYMTL's Avatar
Let the spinning cube spin and look at your GPU usage. Should be @ near 100%. Not as good as the 3Dmark Batch Size tests but it is a close second.
Old July 29, 2008, 12:56 PM
thanks everyone for your help. =) i got 3 instances of "HDR demo" and ATI Tool running.
Old July 29, 2008, 01:07 PM
Instead of opening a new thread i will ask here. I am using GPU-Z to monitor the GPU temps and such while i am running these tests. It is telling me the clock speed is 999mhz... the gtx260 should be 1999 clock speed no?
