  #21 (permalink)
Old August 8, 2008, 09:08 AM
Spaceman-Spiff's Avatar
The EVGA model for example, only requires a minimum of 450w for SLI:
Minimum of a 400 Watt power supply.
(Minimum recommended power supply with +12 Volt current rating of 22 Amp Amps.)
Minimum 450 Watt for SLI mode system.
(Minimum recommended power supply with +12 Volt current rating of 24 Amp Amps.)
An available 6 pin PCI-E power connector (hard drive power dongle to PCI-E 6 pin adapter included with card)
EVGA | Products
  #22 (permalink)
Old August 8, 2008, 09:44 AM
So just for my own clarification after reading this thread all the way through. At the beggining a few people were saying that an Earthwatts 500w wouldn't be enough and then a few more people said it would be then at the end someone reccomended a 650 watt. For the record would the 500w work or would you need more wattage? Thanks just a little confused.
  #23 (permalink)
Old August 8, 2008, 10:59 AM
the 500w should work no problem, but the 650w would be a lot more efficient
AMD Phenom II 940 @ 3.0Ghz | OCZ Vendetta II | Gigabyte GA-MA790GP-DS4H 790GX/SB750 | 2x2gig Musking Redlines 5-5-5-18-24 T2 | XFX 8800GT XT 512MB @ 702/1023 | WD Raptor 36,74gig | OCZ GameXtreme 850w | Cooler Master Cosmos 1000 | Samsung Syncmaster 2443BW | Logitec x530 5.1 | Windows 7 Home Pre.64-bit
