<~----> Switching from nvidia to ATI - Hardware Canucks
Old July 26, 2008, 09:42 PM
"Quote This..."
Default Switching from nvidia to ATI
Hi all,
Time to retire my 8800 GTS. My 4870 will be here monday. Last ATI card I owned was a 9700 pro. I have absolutely zero brand loyalty. I go with the best of each gen.
So, what are the pitfalls, hassles of swapping out an nvidia card for an ATI. Should I reformat or will an uninstall and driver clean work?
Old July 26, 2008, 09:52 PM
No you don't need to reformat - You can try this:
Guru3D - Driver Sweeper
1Tanker's Avatar
Originally Posted by Squeetard View Post
Hi all,
It's possible to do a straight switch, but not advisable. Things will likely get gunged up...fresh install is the best policy, just remember to backup. GL
Old July 26, 2008, 10:22 PM
"Quote This..."
Thanks.
I'll do the driver clean first. If I have grief I will format.
Old July 26, 2008, 11:27 PM
Depends how long you haven't reformatted.....if it's been a while I'd just reformat haha
Antec NSK 6500 w/ TriCool intake, S-Flex F exhaust
Corsair HX520
Gigabyte GA-965P-DS3 Rev1.0 @ 500FSB
Intel C2D E6300 @ 3.5ghz 1.45V
Arctic Cooling Freezer 7 Pro
Mushkin (996576) 2X1GB HP2-6400 @ 1000mhz 5-5-5-15 1.9V
eVGA 7600GT KO @ 630/880
Seagate 7200.10 320GB
Samsung SH-162
Samsung 205BW
Logitech Media Keyboard
Logitech MX518
Old July 27, 2008, 12:07 AM
Spellbot5000's Avatar
I just did the very same thing recently. I first uninstalled the Nvidia drivers, then rebooted in safe mode. There I ran Driver Cleaner to remove anything Nvidia still hanging around. Rebooted back into regular XP, and then ran Crap Cleaner to clear out the registry and any Nvidia dll's. Lastly I searched the registry manually and the hard-drive, and delete any files/entries/whatever that related to Nvidia. One final reboot to start clean and then I installed the new card, and installed the ATI drivers, and everything ran fine.
If you play a lot of games, most should reconfigure themselves properly for your new hardware, but some may freak out because they were configured for your Nvidia hardware when you installed them. If this sort of thing happens, delete any config/cfg/ini files that the games use to store settings and you should be good.
Old July 27, 2008, 12:10 AM
encorp's Avatar
I just like to format so I'm safe, I always worry that even if something dosn't screw up that maybe I'll take an unknown performance hit.
DISCLAIMER: The views and opinions expressed in the immediately preceding post are those of encorp and do not reflect the views and/or opinions of family, friends, or anyone remotely associated with encorp unless explicitly stated. encorp does not make any warranty, express or implied, or assumes any liability or responsibility for the quality, factuality or use of information in the immediately preceding post.
Old July 27, 2008, 05:58 AM
"Quote This..."
I hope I don't have to reformat. I've got 5 OSes on this comp.
Old July 27, 2008, 06:50 AM
Mibs's Avatar
There is a procedure I always follow when installing new drivers, so it should be the same for switching cards. This is a post on the evga forums, so naturally it is specific to nvidia cards, but the procedure is still a good one to follow.
Updating/Installing/Possibly Fixing 8 Series Drivers
Intel C2D E6750 @ 3.52 GHz // EVGA 680i SLI Rev. A1 (P31) // 4 GB OCZ Platinum 800 MHz 4-4-4-15 // PC P&C Silencer 750 Quad // Antec P180 // EVGA 8800 GTS 512 // Samsung Syncmaster 226bw 22" LCD
WC Loop: D-Tek Fuzion V2 // Danger Den Maze 5 // Swiftech MCP655 // Swiftech MicroRes // Thermochill PA 120.2 + 4 x Noctua NF-P12
Old July 29, 2008, 08:20 AM
"Quote This..."
Thanks Mibs, that is what I did. For all my OS's. XP pro 32 for work. XP lite 32 for gaming, xp 64, vista 32 and vista 64. Not one problem with any of those builds.
Great card! My 8800 GTS 640 watercooled at 680/1000 scored 49 fps in mass effect, 28 in Crysis @ 1920x1200. This card did 62 and 34 fps in those same benches at stock speeds. Cod4 is off the hook, 80+ fps at 1920x1200 with 4xAA and max anisio.
Stable at 680/1050 now. Today I'm going to slap on my watercooling and volt mod it. Going for the 850mhz core. If any of the big fall titles bring this thing to its knees I'll slap in another.
