Old July 26, 2008, 10:20 PM
Could it be that somehow it's taking advantage of the HyperThreading on your CPU ?
I've never really compared, as I have a dual core processor and always leave that option on since I play recent games.
Did you try this with other games - Bioshock for example.
Old July 27, 2008, 12:56 AM
I didn't see much of a difference. I ran my timedemo at 1920X1200.
NO
Frames, Time (ms), Min, Max, Avg
4548, 62292, 31, 129, 73.011
YES
4568, 62332, 32, 130, 73.285
Old July 27, 2008, 05:33 AM
i must be retarted for I cant get the time demo to run....
I follwed the instructions and its telling me it cant find the demo...
E8400 Dual Core 4.0GHZ/ 2x 8800 GTX KO ACS3 PCI-E 630MHZ 768MB 2.0GHZ SLI'd / Raptor 74GB / Antec 1200 Hundred Gaming Case / Corsair XMS2 TWIN2X2048-6400C4 2GB 2X1GB PC6400 DDR2-800 CL 4-4-4-12
680I SLI LGA775 MOBO / Samsung DVD+RW / Enermax Galaxy 1000 wats PSU / 24" Samsung CinkMaster
Cooling:
Swiftech Dual rad
Swiftech Single rad
Swiftech Micro Res
Swiftech Apogee GT Cpu block
2x Koolance 8800 GTX Full Coverage Water blocks
Feser One Blue Fluid
Old July 27, 2008, 05:49 AM
well figured I just try the fraps program and use there time benchmark feature..
2008-07-27 07:36:13 - iw3mp
Frames: 11214 - Time: 62789ms - Avg: 178.598 - Min: 26 - Max: 508 (AA off - dual video on)
2008-07-27 07:39:59 - iw3mp
Frames: 6993 - Time: 52176ms - Avg: 134.027 - Min: 27 - Max: 348 (AA on 4x -Dual video on
2008-07-27 07:44:00 - iw3mp
Frames: 4891 - Time: 40955ms - Avg: 119.424 - Min: 24 - Max: 148 (AA 4x -dual cards off)
Cooling:
Swiftech Dual rad
Swiftech Single rad
Swiftech Micro Res
Old July 27, 2008, 06:03 AM
sswilson's Avatar
If I were a conspiracy nut, I'd guess that ATI did something (like a hidden drop in eye candy settings) in the background to boost crossfire performance, but I turned in my X-Files member card years ago so I don't think like that any more............
ASUS SaberTooth 990FX / AMD 1090T / 2X4 Gig Gskill RJ X / XFX Pro 1000W PSU / 2X MSI 560GTX-Ti Twin Frozr II / Corsair F120 / WD 6401AALS
TT Lvl 10 GT / DDCPX-Pro / EK XT 240 Rad / 2X Scythe Ultra Kaze / EK Supreme HF / XSPC 250mm Res / Dell Ultrasharp 2209WA
Asus CH IV / Athlon II X2 250 / 4X2 Gig GSkill Pi PC3-12800 / 2X GTS 450 / PC P&C 750W Silencer / PA 120.2 /
MCR220-QP-Res / Swiftech MCP350 Pump / XSPC Laing DDC top / EK-Supreme HF / Lian-Li Pitstop T60 / Samsung 931BF
Old July 27, 2008, 10:40 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
There we GO!! Was this with a single card?
We need more people to try this with single card solutions.
I have a little theory that I want you guys to listen to.
Remember when sites like Anandtech posted their Crossfire HD4800-series reviews and everyone was calling BS when the CoD4 scores more than doubled when going over to Crossfire? Well, this could be the reason considering you can boost the performance of a single card when enabling the Dual GPU option.....
Thoughts?
Old July 27, 2008, 11:24 AM
Thoughts?
when you guys are referring to single and dual, i assumed you meant going into the game menu settings and shutting off the Dual vid card option in the graphics menu. Was i right in thinking this, or should I have gone into my system and shut off SLI than ran the test? If i did it wrong I can do it again, just let me know... the system has 2 cards installed.
the specs above are as follows...
reading one was with Dual Cards enabled in the game menu
reading 2 was with dual cards shut off in the game menu
Cooling:
Swiftech Dual rad
Swiftech Single rad
Swiftech Micro Res
Old July 27, 2008, 11:26 AM
It's the AMT of data sent when running singlecards....doesn't fully load the gpu. You can check this using DX tools, or various other apps. This is part of what allows COD4 to scale so well on a variety of hardware...single-card threads get less data, and the gpu goes "IDLE".
Part of it is ATI's dispatch processor, but you'll find ALL CARDS SHOW THIS BEHAVIOR, to some extent, axs long as they are not running settings they just cannot handle.
This is just one of quite a few examples out there of good coding in a game engine...
Data could also be sent in SMALLER packets when in dual-gpu mode, allowing for faster transfers...
  #19 (permalink)
Old July 27, 2008, 11:34 AM
I was able to get almost double the frame rate running my 1950pro's in crossfire in COD4 I'm failing to see where the amazement is?
Its been quite documented on Infinity Wards Forums that for some people just selecting dual video card option does increase FPS for whatever reason. It does seem to work on ATI cards and not on Nvidia cards for the most part. This isn't some fantastical thing with your video card its a bug in the game. Whatever optimization is increasing the framerate should be applied to the ' Single Card ' option yet for ATI users its not enabled unless you have it set to 'Dual Card'. You also dont need to be running a time demo to show this, just enable the FPS counter in the game ( open console type fps I think its cg_showfps 1 ). Just open up the options menu and change the option it changes real time you can still see the FPS counter. Pick a spot with particularly low FPS.
Basically think of it as a TURBO option and you might as well leave it enabled until they fix it.. which is unlikely at this point as 4 patches later they havent fixed it.
CPU: E4500@3.3ghz ( 300X11@1.430v) MB: DFI LanParty ICFX3200 T2R/G
RAM: OCZ Platinum XTC rev2 ( 4-4-4-15 2t ) GPU: BFG 9800GTX
COOLING: Swiftech 120 Compact - Swiftech - MCW30 SOUND: HT omega Striker 7.1
CASE: NZXT Lexa Blackline PSU : OCZ Gamestream 700w
  #20 (permalink)
Old July 27, 2008, 11:37 AM
SKYMTL's Avatar
What I am saying is that using a SINGLE CARD while using the ENABLE DUAL GPU option will INCREASE YOUR FRAME RATES EVEN IF YOU ONLY HAVE ONE CARD INSTALLED.
