Old July 25, 2008, 12:44 PM
Default Accelero S1 Rev 2..........
said i would drop a note on the temps. before the change i was getting idle temps of 48 - 51deg C.
now i get an idle of 36-37 deg C and after playing crysis as maxed out as i can ( i let the game choose the settings), i was getting a temp of 48 deg C.
i would say thats another vote for the S1 Rev 2. although i still dont recommend the fan kit. a 120mm fan or perhaps 2 80mm zip tied would do the trick.
cheers
rob123
Old July 25, 2008, 12:48 PM
SKYMTL's Avatar
HardwareCanuck Review Editor
Which card exactly?
Old July 25, 2008, 01:22 PM
misterlarry's Avatar
I use mine passive on my 8800 GTS and it works great. Never seen a loaded temp over 47 degrees C.
Asus Z97-A - Intel i7 4790K @ 4.0 GHz - Corsair H80 CPU Cooler- 4x8 GB G.Skill Ares DDR3 2400 - EVGA GTX960 4GB
1x240 GB Mushkin Chronos Enhanced SSD - 1x500 GB Seagate Hybrid Momentus - 1X2 TB Western Digital Green - Pioneer DVR-212D - Antec P182 - Rosewill Photon 850 - 2X24" Acer G246HYL - Windows 7 Pro 64 SP1
The world is your oyster. Shuck away my friend, shuck away!
Old July 25, 2008, 01:27 PM
Mibs's Avatar
Passive with a load temp of 47C?? That's pretty impressive. You must have some pretty intense airflow going on inside your case.
Intel C2D E6750 @ 3.52 GHz // EVGA 680i SLI Rev. A1 (P31) // 4 GB OCZ Platinum 800 MHz 4-4-4-15 // PC P&C Silencer 750 Quad // Antec P180 // EVGA 8800 GTS 512 // Samsung Syncmaster 226bw 22" LCD
WC Loop: D-Tek Fuzion V2 // Danger Den Maze 5 // Swiftech MCP655 // Swiftech MicroRes // Thermochill PA 120.2 + 4 x Noctua NF-P12
Old July 25, 2008, 03:24 PM
Default forgot the card
the vard itself is an asus 8800gt 512mb. not the highest but enough to make the water in crysis look pretty realistic
rob123
one little minor thing. the temp now doesnt seem to want to go below 40 deg C. before it was around 37-38 deg C.
time will tell i suppose
