Old April 11, 2007, 02:22 PM
mattydies's Avatar
Default nVIDEA Geforce 6200 - Driver issue???
I recently purchased a few budget upgrades.
Pentium D 2.8 CPU (USED E-Bay)
Elite Group P4M800PRO-M (V 2.0) - (new ebay)
nVIDIA GeForce 6200 8X AGP Video card (256 megs of ram) - (new ebay)
- I am not sure if it is an nVIDIA card or just the GPU. I will gladly take a couple pics if it may help
I installed the new hardware, seems quicker when it comes to cpu responce and multi tasking, cpu load is MUCH lower when the processor is under a load (often %50 and running faster then my 2.4 pentium northwood did at 100% doing similar tasks).
Then I realize my comp freezes when I play a video. I can play audio with the same program so pretty sure its not the software.
I decided to re-install windows. my install was not bad, but it could be quicker :)
New install, I get all the drivers installed and such. If I load a video the comp CRAWLS PAINFULLY SLOW. IT usually does not crash or freeze, but it may take between 1 and 3 minutes before I can access the task manager and close the process. LITERALLY 1 - 3 minutes.
ALSO I tried running "Command and Conquer Generals" on the new card. IT CRAWLED ALONG PAINFULLY. perhaps 1/4 of proper speed. I have only seen the game run this slow once, on a 2.0 ghz. Celeron with onboard video.
I ran all the virus and spyware stuff to be sure, normal, then in safe mode, system restore is always off for me, etc. etc. etc. Clean bill of health.
This morning I installed my old ATI 7500 All in Wonder Video card. Now my comp plays videos fine.
Am I having Driver issues? I have tried several different drivers and they all behave basically the same.
Might I have a bad Vid card?
The Box for the card says it needs 350 watts to run stable. my power supply SAYS 400 watts but it is several years old (5?) and its likely well over rated. could this be my problem?
Any help would be greatly appreciated.
Thanks in advance to those who read or reply :)
Matty
Old April 11, 2007, 02:35 PM
sswilson's Avatar
What's the model # of that card?
Are you sure it's a 256meg model or could it possibly be one of the "turbo memory" models that ships with 64meg and uses system memory for the rest?
Old April 11, 2007, 02:42 PM
sswilson's Avatar
This is one of the "turbo cache" cards.
NVIDIA GeForce 6200 TurboCache - Page 1 - The Quick & Dirty on the 6600 and TurboCache
IMO, a person would be better off with on-board video.
Old April 11, 2007, 02:58 PM
mattydies's Avatar
256 meg with only 64 megs of ram? wow, that would be garbage Im sure.
I just took a quick small (164K) pic of my video card and attached it.
I wrote the seller asking if it was an nVidia card or some one else (using an nVidia GPU) and have not heard back. I wrote this morning so I may still get a reply, then again they have my money and feed back, so maybe not.
Hopefully some one knows :)
Old April 11, 2007, 03:06 PM
sswilson's Avatar
What does Display properties/settings/advanced/adapter say about the card?
Can you find a model # anywhere on it?
Old April 11, 2007, 03:23 PM
mattydies's Avatar
The ONLY area that MAY contain a model number is the white sticker on the rear. I have included 2 pics. 1 pic is the Rear of the card. One is that sticker I mentioned. ALL the other numbers seem to be labels to mark components and such for manufacturing.
I will plug the 6200 back in and power up again so I can pull up specs n what not.
Also I pulled the E-Bay url for the item
eBay: NEW Nvidia FX6200/6200 256MB 8x AGP Video Graphics Card (item 250090508843 end time Mar-06-07 15:30:00 PST)
Old April 11, 2007, 03:33 PM
mattydies's Avatar
back and swapped.
about the display properties
Device:
Plug and play monitor on NVIDIA GeForce 6200
Is there anything else I can check to help find the proper make and model of this video card?
Old April 11, 2007, 03:41 PM
sswilson's Avatar
Looks like it's an actual 256 meg card from the description......
I'm looking at the mobo specs now......
Did you disable the on-board vid?
Old April 11, 2007, 03:44 PM
sswilson's Avatar
Originally Posted by mattydies View Post
back and swapped.
Device:
Did you "right click" for display properties then settings/advanced (button)/adapter?
What you got doesn't sound like the right info.....
Old April 11, 2007, 04:11 PM
mattydies's Avatar
I checked CMOS and did not see an option to disable onboard video. I have the AGP set to initialize first (as opposed to PCI). Perhaps there is a header on the MB for this? Is this likely to matter if it is not in CMOS? My 64 meg 4X ATI card plays videos great (have not tried a game, but Im betting it works)
as for my pulling up info from the Advance window I am not sure what you want to know, but here is some info....
I opened the GeForce software and checked Graphics card information
Processor: GeForce 6200
Video BIOS Version: 5.44.A2.06
IRQ: 16
Bus: AGP 8X
Memory: 256 MB
ForceWare Version: 84.21
TV Encoder Type: NVIDIA integrated
Overclocking Issue? Corpus Masochist Troubleshooting 21 April 14, 2008 04:57 AM
PriceMatch 20% Issue! e_1337 Off Topic 1 March 16, 2008 03:58 PM
A7N8X driver/bios issue ebdoradz CPU's and Motherboards 8 January 26, 2008 11:05 AM
NVidea 8800 series OC tutorial Scratch Reviews & Articles from the Web 2 May 18, 2007 11:56 AM
Geforce 8800GTX & 8800GTS Driver release Jan 10 sizerkozak Video Cards 0 January 11, 2007 02:08 PM
