Old April 11, 2007, 01:06 PM
Babrbarossa's Avatar
EVGA
supreme commander = very cool
EVGA 680i SLI 122-CK-NF68-A1,
Intel C2D E6850, EVGA 8800GTX,
OCZ Reaper PC2 8500, Ultra X3 1000W fully modular PSU,
1 Primary Raptor X 150 gig + 2 150 gig Raptors in RAID 0,
Swiftech H20-220 Ultra with a Stealth GPU water block,
Dell Ultrasharp 2407WFP-HC 24" monitor,
Lian Li V2000 Plus Case slightly modded,
Steelseries Akari Laser Gaming Mouse, Razor Tarantula keyboard,
AuzenTech Prelude Sound Card,
Pioneer VSX-1016TXV receiver with Bose 301's,
AKG K240 Phones, Blue Snowflake USB Microphone.
Old April 11, 2007, 01:07 PM
Thank you!
Old April 11, 2007, 04:14 PM
So I just got home chucked that baby in downloaded the current drivers and BAM!! Wow what a huge differnece. COD actually runs decent now. Can't wait to tweak this baby a bit and run some benches to see what I get in comparison to my fellow geeks.
Well I will be talking with you dudes shortly.
Thanks for the pointers.
BTW, I went with the EVGA E-GEFORCE 8800 GTX 575MHZ 768MB 1.8GHZ GDDR3 Dual DVI-I HDTV Out HDCP DIRECTX10 Video Card.
The extra $100.00 or so didn't makes sense which Paul Brooks at NCIX confirmed. Good ol Paul.
Old April 11, 2007, 04:21 PM
sswilson's Avatar
Cool!!!!
All of you high end vid DX10 owners are starting to make me jealous!!! :)
Old April 11, 2007, 07:02 PM
b1lk1's Avatar
A 320MB card is ridiculously memory bottlenecked with higher resolutions. Considering monitors are only getting bigger, the 320MB card is a HUGE waste of cake. GTX all the way with this arguement, although a single 640MB GTS will be more than enough for now and adding another later will be killer.
EDIT: I just noticed you had the 2407 Dell. You would have SEVERELY regretted the 320MB GTS's.
Driving sim: MSI 970 Gaming/FX6300/16GB Corsair DDR3/ASUS CU II R9 290X 4GB/128GB SSD+750GB HDD
Daily: Intel DQ67SW/i7 2600/8GB DDR3/WD 150GB VR+2TB HDD/CU II R9 270 2GB/Xonar D1
Old April 12, 2007, 01:21 AM
I have been making love to my video card all night. Oh man the burns are in need of attention as this card really does get hot. LOL!! I didn't know it took 2, 6-pin PCI express power connectors, defiantly unexpected but not a problem what so ever. I have so many patches from years of messing with this stuff, plus I was/am into audio engineering so....... patches yeah patches.
Well frankly I don't want to typw anymore I want to run the shit outta this thing............. Bye
To be back soon.
CM
Old April 18, 2007, 03:37 PM
DerekOldschool's Avatar
I have the 8800GTS 640M (see sig.) currently running at 633Mhz CPU / 999 Mhz MEM and have been putting it through its paces for the last 6 weeks or so after moving up from a 7900 GT 256M
Do you want to really kick the shit outta that card? I have one acronym for you: S.T.A.L.K.E.R.
Just run that game with Dynamic Lighting enabled and watch the framerates plummet! I have to really scale back the resolution with DL enabled (which made the game look like ass) to have playable frame rates.
With just static lighting enabled instead of dynamic lighting I run it fine at 1600x1200 with AF and AA fully enabled in the game, but man, this card gets hot! Even with riva tuner running the fan at 100% I've hit 78C while playing this game!
F.E.A.R. (another fine acronym ) only gets the card up to 70C, but I cant run it at 1600x1200 at the AA/AF settings that I like, so I guess the memory is not getting the workout that STALKER throws at it.
The heatsink on the card cools the cpu and the memory, so that would explain the higher temps when the memory is adding to the amount of heat that the poor thing has to dissipate. I found a slot exaust fan works good at getting rid of that excess heat
i7-860 @ 4.0Ghz EVGA P55 FTW SLI (E657-A51 Bios) Thermalright ULTRA-120 Trueblack Rev.C G.Skill Ripjaws 4G DDR3-2000 Antec 850W TPQ EVGA 780 Ti Acer X263W 25.5" LCD Crucial C4 256G WD FAEX 1TB LG DVDRAM GH20NS10 Thermaltake Kandalf case Windows 7 Pro x64
E8400 @ 3.96Ghz (1.42v) EVGA 780i A1 (P08) ZalmanCNPS9700NT G.Skill 4G DDR2-1000 eVGA GTX280SC 1G Windows 7 Pro x64 1xSeagate Barracuda 7200.11 500G
  #19 (permalink)
Old April 18, 2007, 03:55 PM
Wow- smokin- that's a pretty high core overclock for stock cooling- have you looked at your temps at 600?
How do you adust the voltages on these GPUs- do people commonly up the voltage or just leave it alone? Does ATI tool do it automatically?
  #20 (permalink)
Old April 18, 2007, 07:57 PM
I'm not quite sure what my actual temps are at 600Mhz because at that time I didn't use Riva Tuner to control my fan, and I'm pretty sure that the nvidia control panel was not turning the fan up when I was putting the GPU under load during games.
As far as voltage goes, I haven't changed any voltages in regards to video. Any change in voltages would be done in the bios - for me anyway. I don't like to change voltages on any piece of hardware from windows. I have never really looked into that possibility with this card, but given the high temperatures that have already been noted, I wouldn't turn anything up any more without more cooling power.
I'm kind of dreading the hot summer months that are just around the corner. All my temps right now are with an ambient room temperature of 18-20C. Wait until it gets 28 - 29C in here! I generally reduce any overclocks or even underclock hardware to avoid meltdowns during heatwaves. It might be time to invest in an air conditioner for the first time in my life.
