Old July 24, 2008, 12:11 PM
magictorch's Avatar
Default XF 4870 stock HIS+visiontech?
Is it ok to crossfire two stock 4870's from different distributors HIS and Visiontech?
Theres a very tempting deal on that visiontech at NCIX.
Old July 24, 2008, 12:19 PM
Mibs's Avatar
I think that as long as they have the same speeds you should be fine.
Intel C2D E6750 @ 3.52 GHz // EVGA 680i SLI Rev. A1 (P31) // 4 GB OCZ Platinum 800 MHz 4-4-4-15 // PC P&C Silencer 750 Quad // Antec P180 // EVGA 8800 GTS 512 // Samsung Syncmaster 226bw 22" LCD
WC Loop: D-Tek Fuzion V2 // Danger Den Maze 5 // Swiftech MCP655 // Swiftech MicroRes // Thermochill PA 120.2 + 4 x Noctua NF-P12
Old July 24, 2008, 12:32 PM
SKYMTL's Avatar
HardwareCanuck Review Editor
Yes, it is OK.
Old July 24, 2008, 12:42 PM
Even this doesn't matter. Neither does memory size.
Speeds stay the same, memory bumped to amt on lowest card.
