Old July 16, 2008, 11:59 PM
Jon_di2's Avatar
Question Gtx 260 Vs. HD 4870 - Same Price
GTX 260 and HD 4870 dropped to the same price, Which one to buy? - Expreview.com
Now that the prices are the same, which one is better? With close benchmarks, which one will prove to be better for games in the future?
EVGA E-GEFORCE GTX 260 576MHZ 896MB 2.0GHZ GDDR3 PCI-E Dual DVI-I HDCP HDTV Out Video Card - $267.86CAD after mail in rebate
Diamond Radeon HD 4870 512MB GDDR5 PCI-E 2XDVI-I Video Card - $268.32CAD
Opinions? I'm thinking that the Gtx 260 might prove to be better for future games. And there might be some advantages to one or the other if you are using Crossfire or SLI, and in regards to overclocking. But really its a coin toss at this point.
Old July 17, 2008, 01:51 AM
burebista's Avatar
I dunno, it's a hard decision. If you want raw power and PhysX go for nVidia. If you want somehow better IQ and HD decoding go for ATI.
Frankly I'm a nVidia user. From GeForce 2MX to 8800GT. But now I'd go for HD4870. My impression is that it's overall better than GTX 260. Only drawback is the same old story for ATI: drivers, but with patience will appear good drivers.
Old July 17, 2008, 02:22 AM
nVidia vs ATI;
drivers - nVidia (Catalyst will always be a resource hog)
dual card - ATI
PhysX support - nVidia (soon to be both nVidia and ATI)
Havok - ATI
Bottom line the 4870 gets a few more FPS.
Old July 17, 2008, 04:28 AM
Mibs's Avatar
At this point now that the prices are the same there really is no clear winner here. It's now basically up to the consumer if they want to go nvidia or amd. There are loads of benchmarks that will show that it all depends on the application for deciding which is faster.
Intel C2D E6750 @ 3.52 GHz // EVGA 680i SLI Rev. A1 (P31) // 4 GB OCZ Platinum 800 MHz 4-4-4-15 // PC P&C Silencer 750 Quad // Antec P180 // EVGA 8800 GTS 512 // Samsung Syncmaster 226bw 22" LCD
WC Loop: D-Tek Fuzion V2 // Danger Den Maze 5 // Swiftech MCP655 // Swiftech MicroRes // Thermochill PA 120.2 + 4 x Noctua NF-P12
Old July 17, 2008, 05:25 AM
I gave in and bought an EVGA GTX 260 FTW (factory overclocked) from NCIX. Was originally going to go for the 4870 but after seeing the evga card approach GTX 280 performance in many tests and even suprass it in Crysis performance (EVGA GTX 260 FTW Edition Review - Overclockers Club) I thought what the hell I'll shell out an extra $50 or so after rebate and go for the extra power.
Old July 17, 2008, 05:43 AM
Jon_di2's Avatar
Remember the OC'd ones make more heat and take more power (you will need a better psu), also you can overclock it yourself (probably not as well as the factory OC though)
Old July 17, 2008, 06:52 AM
Cheator's Avatar
It depends. Power consumption is about on par for both cards at stock, performance evens out to be mostly the same... I'd go for the 4870 just because of Crossfire, adding a cheap 4850 in the future will make that rig fly. But in other ways its a toss up.
Optimus: Antec P180, Asus P5Q-E, E8400, 4 GB RAM, Asus 4850, Seagate 320gb, Antec TC II
Teletraan I: Asus P5K-E/WIFI, E4500, 2 GB RAM, ATI 3450, Sapphire Theatrix, 2.25TB storage, Antec SP2 400w
Galvatron: Asus M2NPV-VM, 3800+ X2, 2GB RAM, NV8500GT, Seasonic 500w
Tracks: Acer AS5920, C2D 2.1ghz 45nm, 3GB DDR2, NV8600m GT, 250gb hdd
Hound: Gigabyte GA-MA74GM-S, AMD 4400+ X2, 1 GB RAM, 2900XT, 500w Seasonic
My Heatware!
| Got RMA? Tell us your experience! | VOIP Help? PM ME!
Old July 17, 2008, 09:09 AM
Eldonko's Avatar
Hardware Canucks Reviewer
Personally I would go with 4870 because I find CF is better than SLI, however when performance is this close it comes down to brand preference and what kind of board you already own. I also find that in general there are more goof CF boards than SLI boards.
The only reason I would even consider nvidia right now is for folding performance.
Old July 17, 2008, 11:27 AM
lowfat's Avatar
I don't know where you've been the past few years, but ATI drivers are significantly better than Nvidia's.
1. Xeon ES 4c/8t * X79-UD3 * HD7970 * 16GB DDR3 * 64GB Crucial M4 * 80GB ioXtreme * 1000W Silverstone
2: 27" iMac * i5 750 * 80GB X25-M G2 * 4GB DDR3 *
3: 2600k * P8P67 Pro * GTX460 * 16GB DDR3 * 40GB X25-V * RR2314 * (2) Sans Digital TR8M-B * 46TB * 1050W Enermax
Old July 17, 2008, 11:51 AM
burebista's Avatar
Even I live in Romania we have net here. And TV too.
It's your opinion about ATI drivers, let me have my own, OK? Thanks.
