Old June 30, 2008, 08:49 PM
Leclerc's Avatar
If it works well, I may consider give a try to CF sooner than I thought.
Leclerc
AthlonX2 4600+ @ 3.0Ghz (tweaked by Ebdoradz) | Gigabyte MA790X-DS4 | 2x1GB Mushkin HP PC2-6400 @ 860Mhz | Silverstone Strider 500W PSU | Palit Radeon HD 3850 @ 720Mhz/1.76Ghz on 22" Acer X223w monitor | Thermaltake SopranoRS 101 | 1 x Seagate 250GB
Old June 30, 2008, 09:58 PM
SKYMTL's Avatar
HardwareCanuck Review Editor
Originally Posted by Boldeagle View Post
Damn a nice way to upgarde if you can still use the old card and an excellent way to get a CrossFire on a budget if I buy a 3870 later sounds very interesting . Going to pick up my 4850 right now damn excited as it's going to be a BIG upgrade for me. Can anyone shine light on the Drivers I will need some are saying they just installed card, uninstalled 8.6 and then reinstalled with new card onboard and everything went well, while others are saying you need "hotfix" and that has lead them down a path of misery and BSOD.....I'm confused.
The Hotfix is NOT NOT NOT NOT meant to be installed on top of old drivers. "Hotfix" is a name that ATI gives to their BETA DRIVERS so you should go through the whole uninstall process of the old drviers and then install the Hotfix as you would install regular drivers.
Use the Hotfix.
Old July 1, 2008, 08:55 AM
ChuckleBrother's Avatar
Kinda doubtful that this will work, besides, doesn't CF underclock the more powerful card when you tag together two dissimilar cards?
"...you play a mean banjo"
Old July 1, 2008, 08:58 AM
vinister's Avatar
Maybe but a 3870 will easily do the clock speeds of the 4870, so even if it did get evened out, no big deal.
My bet is that it will work for some games, but will be unsupported, and may have problems.
Mobo: DFI 790X-M2R
Proc: AMD PHENOM X3 720
Ram: OCZ Platinum 2X 2GB @ 1066
VIDEO: 3 x Visiontek HD3870
Old July 1, 2008, 09:22 AM
Cheator's Avatar
3850+3870 CF is almost as good as 2x3870s and better than 2x3850s, so its hard to say.
Optimus: Antec P180, Asus P5Q-E, E8400, 4 GB RAM, Asus 4850, Seagate 320gb, Antec TC II
Teletraan I: Asus P5K-E/WIFI, E4500, 2 GB RAM, ATI 3450, Sapphire Theatrix, 2.25TB storage, Antec SP2 400w
Galvatron: Asus M2NPV-VM, 3800+ X2, 2GB RAM, NV8500GT, Seasonic 500w
Tracks: Acer AS5920, C2D 2.1ghz 45nm, 3GB DDR2, NV8600m GT, 250gb hdd
Hound: Gigabyte GA-MA74GM-S, AMD 4400+ X2, 1 GB RAM, 2900XT, 500w Seasonic
My Heatware!
| Got RMA? Tell us your experience! | VOIP Help? PM ME!
Old July 11, 2008, 01:22 PM
Cheator's Avatar
Took a while but the 4850 has arrived! I will install it tonight and see how it blends :)
My Heatware!
Old July 11, 2008, 04:20 PM
Cheator's Avatar
This is an odd one...
4850 is the only card seen in CCC. the 3850 is nowhere to be seen in it, but its detected fine. Shows up in Device Manager, GPU-Z. I thought maybe its because the cat 8.7s' install directory is labled R700. To be sure, I installed the 8.6s on the 3850 but kept the 8.7 betas on the 4850 with no success. Looks like she doesn't wanna come out and play... maybe I should wait for the 8.7s to come out? do we have a date for them?
My Heatware!
Old July 21, 2008, 07:43 PM
Cheator's Avatar
Looks like it won't work without some tinkering.. damn... sorry guys!
My Heatware!
