Old June 29, 2008, 06:03 PM
Originally Posted by CanadaRox View Post
And I'll tell you to read the whole thread. (We make fun of each other on MSN every time we have to correct the other person).
So you mean dual 8x isn't going to give a huge performance increased over 16x if I am thinking right.
Even if I am running resolutions lower than 1600x**** I should still see more performance increase is that right ?
Old June 29, 2008, 06:15 PM
SKYMTL's Avatar
HardwareCanuck Review Editor
If budget doesn't figure into your equation, I would say skip the computer altogether, buy a Lambo, pick up some blond triplets and hop in your private jet to Martinique for a love-in.
Or get the HD4870.
Old June 29, 2008, 06:38 PM
Or get the HD4870.
I think the first one sounds very interesting SKY . Unfortunately the second option is more affordable
Thanks SKY
Old June 29, 2008, 06:52 PM
SKYMTL's Avatar
Ah HA!! So there IS a budget. Well, you have made the right choice....in terms of a GPU that is.
Old June 29, 2008, 06:55 PM
I was looking at 2 x 4850 crossfire... I think I will settle with 2x4870s probably
Old July 1, 2008, 04:51 PM
It looks like I might just settle with the 4870's, Currently I have a 8800GTS 512 (G92 core), and the review I just saw from SKY of the 4850 card, there isn't that big increase in performance btw the 2 cards, and in some single card benches, the 4870 beats the 4850 by a good noticeable margin..
