Old June 26, 2008, 10:21 AM
Default HR-03 on Sapphire 4850
I have an HR-03 cooler that I used on my 8800GTX..
Can I use this on my new 4850?
If not what are the differences between the HR-03 and GT versions??
I looks like it might fit..?"
Intel i7 920 Stock Speed
Corsair H50 Hydro Cooling Kit
ASUS P6T Deluxe V2 Motherboard-
1 Powercolor HD 5850 1Gig Card
6 GB Patriot Viper 1600-
Antec P182 Gunmetal Grey Case
5x1TB BlackWestern Digitals -
2X PIONEER DVR-212D DVD-RW - 24" Samsung 245T LCD -
OCZ Game X Stream 600 -
WINDOWS 7 Premium 64BIT
Old June 26, 2008, 10:28 AM
magictorch's Avatar
I think the mounting brackets are different and thats about it. I hope so anyway as Id like to port my HR-03 plus onto one of those 4870's
Old June 26, 2008, 02:59 PM
Eagle Eye's Avatar
If you are refering to the HR-03 Plus for the 8800 series from nVidia then magictorch is correct. The main difference is the HR-03 GT is compatible with nVidia and ATI cards, the HR-03 Plus is only compatible with nVidia G80 GTS, GTX and Ultra cards.
As far the HR03-GT that is fully compatible with both the 4850 and 4870 as stated on thermalrights website and what we have seen in SKTMTL's review. Regardless getting a HR03-GT for your 4850 would be a worth while upgrade as the results from SKYMTL's review of the 4870 provides the most superior cooling I have ever seen and I bet that it would be just as effective on the 4850.
Old June 26, 2008, 11:59 PM
Well it fits on the Palit 4870:
Palit Radeon HD4870 512MB Graphics Card Review
So that could be a good indication.
Q6600@3.15Ghz|CNPS9500|GA-EP45T Extreme|GSkill 2GB 1333MHz|Sapphire 4850|OZC GameXtreme 700|XP64
