Originally Posted by SKYMTL
Thanks for the compliment and welcome!!
This is actually a very interesting question since I have seen a few people say that their cards idled at high temperatures and others have around my temps. There is another option to see your GPU temp right now and that is with GPU-Z. In GPU-Z you can click on the "Sensors" tab to get temperature readings that refresh a little more frequently than CCC. They both read from the same sensor so the temperatures should be the same but I prefer the GPU-Z method for now.
What are your load temperatures? To find this out, simply download ATITool and let the spinning box spin for about 10 minutes while keeping your eye on the GPU-Z sensor readout. I would love to know what your temperatures are under load.
I will pop in my other HD4870 tonight since I have a funny feeling that the TIM application or copper base isn't consistent on these cards. |
I will dload these tonight and give em a whirl!
Originally when I was benching this card, the card never spun up. My whole first night was like that. I have a feeling it was not changing clocks like it was supposed to. Then someone read my mini user review at Rage and stated my scores looked lower than what he expected. I re-tested and I in fact got some higher scores! But then as I was playing Crysis or watching 3DMARK06 run, the fan would rev up and down repeatedly. Basically alternating between high and low speed the whole time in intervals of approximately 3 - 5 seconds. Almost like it was ... "oops to hot" ... "ok I'm fine now".... "oops hot again!". /sigh.
I hope they adjust this. I would simply prefer that the driver choose quiet with a regular fan speed and then as soon as 3D is on... Bam! Straight to 30% so you can just hear it or whatever but stay there so I am not distracted by the revving of the fan speed.
Coinciding with these intermittent fan speeds, my scores in some of the tests in fact improved! Weird.
I will dload ATITool and play around some.
C.
