Old June 24, 2008, 12:50 PM
Spaceman-Spiff's Avatar
Default 9800 GTX+ Preview from Anand
The specs are as follows:
9800 GTX+9800 GTX
Stream Processors128128
Texture Address / Filtering64 / 6464 / 64
ROPs1616
Core Clock738MHz675MHz
Shader Clock1836MHz1690MHz
Memory Clock1100MHz1100MHz
Memory Bus Width256-bit256-bit
Frame Buffer512MB512MB
Transistor Count754M754M
Manufacturing ProcessTSMC 55nmTSMC 65nm
Price Point$229$199
Conclusion:
The Radeon HD 4850 continues to be a better buy than NVIDIA's GeForce 9800 GTX, even if both are priced at $199. The overclocked, 55nm 9800 GTX+ manages to rarely outperform the 4850 but for the most part isn't competitive enough to justify the extra $30. AMD was quick to point out that by the time the 9800 GTX+ ships that it will also have factory overclocked 4850s, which should make things even more interesting. Because, honestly, a factory overclocked Radeon HD 4850 is far more attractive to us than an overclocked GTX+.
Article: AnandTech: NVIDIA's First 55nm GPU: GeForce 9800 GTX+ Preview
Old June 24, 2008, 02:26 PM
Cheator's Avatar
lol. Wow... imagine the factory OCed 4850s and this one. Dang yo.
Optimus: Antec P180, Asus P5Q-E, E8400, 4 GB RAM, Asus 4850, Seagate 320gb, Antec TC II
Teletraan I: Asus P5K-E/WIFI, E4500, 2 GB RAM, ATI 3450, Sapphire Theatrix, 2.25TB storage, Antec SP2 400w
Galvatron: Asus M2NPV-VM, 3800+ X2, 2GB RAM, NV8500GT, Seasonic 500w
Tracks: Acer AS5920, C2D 2.1ghz 45nm, 3GB DDR2, NV8600m GT, 250gb hdd
Hound: Gigabyte GA-MA74GM-S, AMD 4400+ X2, 1 GB RAM, 2900XT, 500w Seasonic
My Heatware!
| Got RMA? Tell us your experience! | VOIP Help? PM ME!
Old June 24, 2008, 02:30 PM
zlojack's Avatar
These new ATI cards sure are impressive.
[SIZE=3]
Old June 24, 2008, 03:05 PM
I found this part the most interesting.
"In a little over 12 hours we'll be able to complete the story with a full look at AMD's RV770 GPU and the Radeon HD 4870, so for a full, detailed performance analysis come back then. Until then, in short, the 9800 GTX+ doesn't really change anything for NVIDIA."
Old June 24, 2008, 03:20 PM
belgolas's Avatar
lol it is just an overclocked GTX. So lame. and the memory isn't overclocked at all.
Sponsor a child!
Fight poverty.
Qoute by Perineum
"ID10T. I just BETCHA he's got 9 toolbars on his web browser right now."
Old June 24, 2008, 03:54 PM
55nm vs 65nm
smaller die
Old June 24, 2008, 05:32 PM
Mibs's Avatar
There are two ways to look at this. Yes it is lame that they released yet another 9800gtx that is just barely overclocked. But on the other hand like the article mentioned they have now moved to a 55nm manufacturing process. This is not so lame, since they will hopefully use this from now on. Even though more FPS are important, power draw is becoming more and more important each day. I am not praising this revision of the 9800gtx by any means, just by looking at the graph we can see that is only uses a few less watts. But what's more important is what it can bring for the future of nvidia products. If everybody had a 55nm card over a 65nm card that amount of power that would be saved would be enormous.
In other news, I'm still way more interested in the new AMD products as well!
Intel C2D E6750 @ 3.52 GHz // EVGA 680i SLI Rev. A1 (P31) // 4 GB OCZ Platinum 800 MHz 4-4-4-15 // PC P&C Silencer 750 Quad // Antec P180 // EVGA 8800 GTS 512 // Samsung Syncmaster 226bw 22" LCD
WC Loop: D-Tek Fuzion V2 // Danger Den Maze 5 // Swiftech MCP655 // Swiftech MicroRes // Thermochill PA 120.2 + 4 x Noctua NF-P12
Old June 25, 2008, 06:50 PM
no_pulse's Avatar
Would it be worth it to wait until the 9800 GTX+ are released mid July? It seems that other than the Core clock, Shader clock and Mem clock, the 280 is a little more faster. But is it worth the extra $300 more for the 280?
Geforce 9800 GTX+
Stream Processors 128
Core Clock (MHz) 738MHz
Shader Clock 1836MHz
Memory Clock 1100MHz
Memory Bus Width 256-bit
Frame Buffer 512MB
Transistor Count 754M
Price Point $299
GeForce GTX 280
Stream Processors 240
Core Clock (MHz) 602MHz
Shader Clock 1296MHz
Memory Clock 1053MHz
Memory Bus Width 512-bit
Frame Buffer 1024 MB
Transistor Count 1.4 billion
Price Point $600+
Old June 25, 2008, 08:54 PM
Infiniti's Avatar
Maybe this was part of ATI's "Plan". They let NVIDIA take the spotlight in 2007, while they were preparing for 2008, releasing a bunch of awesome cards that will blow NVIDIA away.
