  #41 (permalink)
Old June 17, 2008, 12:58 PM
bojangles's Avatar
While this card seems like it's on it's way to perform many FLOPS, I still don't think this is a big step in gaming. They should have just left the non-gaming stuff to their workstation and server stuff.
Honestly, what I think nvidia did was slap all those GX2 transistors onto one die. Pure stupidity I think. We're looking for more efficiency, not insane power consumption. They should have went to 55nm to take some of the heat off.
  #42 (permalink)
Old June 17, 2008, 01:04 PM
CMetaphor's Avatar
Quadfather
That's one of the biggest reasons that my next video card(s) will be from AMD/ATI. Right now with my two 8800GTS 320mb's in SLI the "upper" one (which has 2x Coolermaster 120mm fans pointing right at it from the side) Is constantly about 10 degress hotter than the lower one (which has 2x Antec Tricool 120mms pointed at it from the bottom). Considering that the Coolermaster fans are running on MAX and the tricools are running on "Low" I'm very disappointed with how well these 65nm Graphics cards handle heat. I can only imagine how hot the 3x SLI GT280's get (from that guy on the XS site) but I have no doubt it's unbearable. Just my opinion.
  #43 (permalink)
Old June 17, 2008, 01:26 PM
zlojack's Avatar
Great review SKYMTL as per usual. Thorough, informing and just generally very good.
This card does look like a beast, but it hasn't blown me away.
I'll be waiting for the 4870 and X2 to see how they compare.
Certainly going to be interesting, but unless I see something that blows me away, I'm not changing my setup for a while.
  #44 (permalink)
Old June 17, 2008, 01:46 PM
MpG's Avatar
MpG MpG is offline
Originally Posted by CMetaphor View Post
...I'm very disappointed with how well these 65nm Graphics cards handle heat.
Your GTS 320's are actually 90nm, which is one of the reasons they run so hot.
  #45 (permalink)
Old June 17, 2008, 03:09 PM
S_G's Avatar
S_G S_G is offline
Looks awesome, though that's quite a hefty price tag. Guess I'm glad to be going ATI this time around.
  #46 (permalink)
Old June 17, 2008, 06:43 PM
DX10 performance on crysis must of been pretty bad for you to test it in dx9?
  #47 (permalink)
Old June 17, 2008, 07:32 PM
SKYMTL's Avatar
HardwareCanuck Review Editor
I chose to test in DX9 since I feel that DX10 at High settings does nothing but impact performance with ZERO visual benefits. I try to stay as realistic as possible in as many tests as possible which means I test at resolutions and settings I myself would use. IMO, if someone decides to play Crysis with DX10 on they are a sucker for punishment based on the lack of benefits it offers.
I don't add certain tests because the hardware did bad or had less than pleasing performance. I keep said tests out because no one in their right mind would actually use the settings theses tests would involve.
  #48 (permalink)
Old June 17, 2008, 08:21 PM
Retro's Avatar
Another excellent review from SKYMTL
One of my favorite features is the customary fitting of a Thermalright heatsink. Although, in this case, it didn't work but good show trying both. I would think that Thermalright will have a cooler for the 200 series soon enough. I bit the bullet after work today and joined the EVGA step-up list for a 280. I know it isn't going to blow away my GX2 but I look forward to leaving behind the stuttering and getting back the gaming smoothness that I had with my previous single-gpu 8800GTS640 and G92 512 cards. And of course, being able to bolt on a Thermalright HR-03 type cooler with a good 120mm fan.
Too bad I'm #255 in the waiting listI guess it will be a while before I get to play with the new toy
Latest build:
i5 750@3800MHz 20x190@1.38125v
Noctua NH-U12P/NF-P12
4G GSkill DDR3 2000 Ripjaws
Asus P7P55D-Pro
2x EVGA GTX275 in SLI
PC P&C 750 Silencer
Cuda 500
Antec 902
W7 64 RTM
  #49 (permalink)
Old June 17, 2008, 08:27 PM
S_G's Avatar
S_G S_G is offline
I agree with you about DX9 vs DX10 at high settings, but at very high there is quite a noticeable difference. Even when you unlock the very high settings in DX9, there are some missing features. Most notably, the handling of soft particles, volumetric lighting and dynamic shadows. For me, dynamic shadowing is the best current use of DX10 technology. Clouds casting shade adds considerable realism to a scene.
  #50 (permalink)
Old June 17, 2008, 08:48 PM
SKYMTL's Avatar
For the fun of it I just tried my usual custom timedemo on Very High settings in DX10 @ 1280 X 1024. The resulting slideshow from the GTX 280 and GX2 was telling enough about two things:
- No one is going to but this card to run Crysis at 1280 x 1024 at very high settings
- Crysis is ahead of its time. It looked REALLY REALLY good...
- My custom timedemo is VERY different from the usual "benchmark" since that "built in" BS achieved a 32FPS average on the GX2. Optimizations anyone???
