  #41 (permalink)
Old June 12, 2008, 07:41 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
I have not been able to use a 9800 GX2 without an 8-pin connector attached. Go ahead and try the two 6-pin connector method...the worst that can happen is your system starting.
  #42 (permalink)
Old June 12, 2008, 08:30 AM
Rapid-X's Avatar
lol been tryin all morning i dont get paid till nex friday so i cant even pick up a adapter. so far no luck anyone have a 6-8 pin lieing around??
  #43 (permalink)
Old June 12, 2008, 09:48 AM
SKYMTL's Avatar
Can you fit a 6-pin into the 8-pin socket?
  #44 (permalink)
Old June 12, 2008, 01:24 PM
Rapid-X's Avatar
yeah but it leaves 2 pins open inwhich from what i heard is just ground pins, cause my psu has 2 pci-e 6 pin connecters
  #45 (permalink)
Old June 12, 2008, 01:41 PM
SKYMTL's Avatar
PM me your full address. I'll send you one of my custom ghettoized dual ground connectors made from a Molex to 6-pin cable that I use for PSU reviews on products without the 8-pin connectors. I've got a few I made so I can spare a buck or two to send one to you.
  #46 (permalink)
Old June 16, 2008, 07:01 PM
334th_Frenchie's Avatar
Thats the thing about you easterners always looking out for one another :)
HP M8000n Media Center AMD Athlon 64 X2 5200+ Dual Core 2.6GHz, 4GB Kingston 667mhz RAM, BFG 9800GTX OCX 512 Ram, Asus M2N Motherboard, OCZ 700w Gamer Extreme PSU, Samsung 22" 226bw, Vista Home Premium SP1, Altec Lansing Speakers
  #47 (permalink)
Old June 17, 2008, 07:50 AM
Rapid-X's Avatar
lol heading to montreal in 3 weeks goin to pick up some rims i bought might stop in n take sky 4 a drink
  #48 (permalink)
Old June 20, 2008, 12:16 PM
Rapid-X's Avatar
Default 9800 again
finally i got the card 9800gx2 to go all great but still no video
  #49 (permalink)
Old June 20, 2008, 12:56 PM
Chilly's Avatar
you got it working but its not working? are you apple2gs in disguise? ([H] GenMay refrence).
okay I'm gonna assume you mean it boots and turns on but no video, try the other dvi port, other than that do you get any beeps? also try resetting the cmos/bios
  #50 (permalink)
Old June 20, 2008, 03:19 PM
SKYMTL's Avatar
Rapid, I still need you phone number which I asked you for a while ago so I can mail this thing to you. Please PM me ASAP.
