  #21 (permalink)
Old June 11, 2008, 11:41 AM
magictorch's Avatar
Maybe it was his birthday and someone close got confused with the naming system and bought the wrong card off ebay. Or its just one of those special GT's.
  #22 (permalink)
Old June 11, 2008, 11:57 AM
Rapid-X's Avatar
Originally Posted by SKYMTL View Post
Rapid. Do you have any Molex to 6-pin adaptors? If so, you can modify one of those into an adaptor....the only issue is that you will need to make sure your 6-pin PCI-E connector fits into the 8-pin slot on the card.
wtf is that lol $6 is alot when u jsut quit ur job and u want to get a sysgtem up n running real quick i live in a small town went there to get the 6-8 pin connector showed then the video card he thought it was a whole computer said that cant be a video card its too big lol townies. let me kno what a molex is so i can look around my basement
  #23 (permalink)
Old June 11, 2008, 12:13 PM
Eldonko's Avatar
Hardware Canucks Reviewer
I want to shop where you do if you are getting 9800gx2 when you think you are getting an 8800 haha :D
  #24 (permalink)
Old June 11, 2008, 12:14 PM
Cptn Vortex's Avatar
Molex is a mystical ferocious being that lives in dark places. Like BoogeyMan, or ChupraCabra.
The Vortex H20
MSI Z87-G45 Gaming
i5 4690K @ 4.5GHZ
SLI GTX 1070
12GB GSkill Ripjaws X 2133MHZ CL10
OCZ Z-Series GOLD 850W
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Watercooling:
  #25 (permalink)
Old June 11, 2008, 12:15 PM
Rapid-X's Avatar
had no clue what it was i thought it was a 9800 to begin with but somone on the forum told me g92 is 8800gt/gts. didnt shop got it as a present/ freebie from a source
  #26 (permalink)
Old June 11, 2008, 12:51 PM
SKYMTL's Avatar
HardwareCanuck Review Editor
There are 2 G92 cores in one GX2.
  #27 (permalink)
Old June 11, 2008, 12:53 PM
Rapid-X's Avatar
o , i think i found a solution im gonna ground the 2 slots to each other and use my secondary pci-e 2 6pin to power it i herd the 2 extra pins are ground anyway
  #28 (permalink)
Old June 11, 2008, 01:17 PM
SKYMTL's Avatar
Can you draw a diagram? I ask because you are playing with electricity here and you could potentially fry your $600 card if you route the wrong wires.
  #29 (permalink)
Old June 11, 2008, 01:40 PM
Rapid-X's Avatar
here is the eight pins from what i have been readyin it should be g =G, L = live 12 v
G L L L
G G G G
  #30 (permalink)
Old June 11, 2008, 02:39 PM
lmao this is pretty funny, and you should post some pictures of this ghetto thing your building =]
