Old June 11, 2008, 09:50 AM
Rapid-X's Avatar
lol im so ghetto about this im making my own 8 pin plug lol using the 2 cpu 4 pins and then im connectin a 4 pin off another psu to cpu lol will take pictures when done wish me luck.
Old June 11, 2008, 09:56 AM
Rapid-X's Avatar
lol cant find electric tape so im stuck with cloth pins makin the separation so they dont touch
Old June 11, 2008, 10:02 AM
Rapid-X's Avatar
didint work on my way out to get one now lol
Old June 11, 2008, 10:14 AM
ahaah wtf
Old June 11, 2008, 10:20 AM
Cptn Vortex's Avatar
How did you manage to mistake a 9800GX2 with a 8800GT? It's a decent card....
The Vortex H20
MSI Z87-G45 Gaming
i5 4690K @ 4.5GHZ
SLI GTX 1070
12GB GSkill Ripjaws X 2133MHZ CL10
OCZ Z-Series GOLD 850W
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Watercooling:
Old June 11, 2008, 10:24 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
Rapid. Do you have any Molex to 6-pin adaptors? If so, you can modify one of those into an adaptor....the only issue is that you will need to make sure your 6-pin PCI-E connector fits into the 8-pin slot on the card.
Old June 11, 2008, 10:57 AM
thenewguy001's Avatar
So you somehow "acquired" a $500 card from "sources", don't know what it is, and now won't fork out $6 for a proper connector.
i5 2500K @ 4.0 GHz
2 x 4GB G.Skill Ripjaws X
Patriot Pyro 240GB
Gigabyte HD 6970 OC
Gigabyte Z68X-UDH3-B3
Seasonic 760W
Coolermaster Hyper 212+
CM690 w/ 1-80mm, 6-120mm fans.
Old June 11, 2008, 11:02 AM
SKYMTL's Avatar
This is Rapid-X we are talking about. Expect the unexpected. :D
  #19 (permalink)
Old June 11, 2008, 11:05 AM
I expect someone ranting in the off topic forum about losing his new GX2 to a burglary.
i5 2500K @ 4.0 GHz
Patriot Pyro 240GB
Gigabyte HD 6970 OC
Seasonic 760W
  #20 (permalink)
Old June 11, 2008, 11:23 AM
werty316's Avatar
AH HAHAHA! This thread is classic!
If you can see Chuck Norris, he can see you. If you can't see Chuck Norris you may be only seconds away from death.
