I hope NCIX gets these in soon, looking forward to testing them with an SLI rig I'm building. Any thoughts anyone?
Ultimate Cooling Weapon for Hardcore Gamers Designed to offer a powerful VGA cooler for maximum overclocking potential, the Accelero XTREME 9800 is compatible with the latest nVIDIA GeForce 9800 GTX. Main features
• Maximum 29°C lower than standard cooler
• 3 ultra quiet 80mm PWM fans with low noise impeller
• Efficient heat dissipation via 5 heatpipes and 107 fins
• Patented fan holder eliminates the buzzing sounds
• Memory and voltage regulator cooling
• Pre-applied MX-2
• Maximises overclocking potential
• SLI compatible
33% cooler than stock cooler
Designed based on the acclaimed Accelero XTREME 8800, the Accelero XTREME 9800 is an even more powerful cooling solution for enthusiasts. Five 6mm heat pipes and 107 fins dissipate heat from the GeForce 9800 GTX card. Together with three 80mm PWM fans that transfer heat efficiently, the Accelero XTREME 9800 achieves up to 240 Watt cooling capacity, resulting in a 29°C temperature reduction from the stock cooler. In addition to the outstanding cooling performance, using the Accelero XTREME 9800 will also bring gamers a better overclocking experience and an extended service life of the graphics card. Quietness matters
Same as other ARCTIC COOLING products, the Accelero XTREME 9800 not only excels in cooling, it also offers excellent noise management. Its three 80mm PWM fans are made by low noise impellers and are installed in a unique fan holder in order to eliminate any buzzing sounds. The efficient noise control design enables the Accelero XTREME 9800 to minimize the noise level to 0.7 sone. Enjoy the coolness and quietness brought by the Accelero XTREME 9800 today!
Well, I guess no one has a 9800GTX...22 views and no responses...ok, I can take a hint, I won't bother posting stuff anymore, I'll just read from now on...I guess this will kill my chance of the winning the ipod huh...lol
I didn't mean the above as seriously as it reads, I should have read it back to myself before posting, I was probably just in a bad mood because the Penguins lost....lol....my apologies, you can put my name back at the top for the ipod now...lol
It's been like 5 hours relax:) outta those 22 views how many were spiders?
My thoughts...... if it performs as well as AC's S1 it should be a hell of a cooler.
R.I.P.
Originally Posted by 3.0charlie
Not everyone leaves a response, give it some time.
by the way that cooler does look good, wanting to put a after cooler on my 8800GT, this might be the one.
Watercooling:
EK Supreme HF, EK FC GTX 680 Block, MCR320+Gelid Silent 12 Push/Pull, DD Pump, EK Multioption 100ml Res, EK Coolstream XT 220 RAD Gelid Wings Push/Pull.
Seems, like to me that you need a Thermalright cooler that SKYMTL always uses for his "aftermarket cooler installation" page featured in recent new vid card reviews.
