Old March 30, 2007, 01:13 PM
ragenrok's Avatar
Default Drivers?
I've got a 8800 GTS on the way i'll be recieving today, and i was wondering. When i got to install the drivers for this card, do i need to remove the drivers for my computers integrated nvidia 6100 card or can I leave those drivers installed as well?
Old March 30, 2007, 01:36 PM
sswilson's Avatar
What board are you running?
Is it designed to allow a second card to be run in conjunction (ATI 480 based chipsets allow this) with the on-board or does it automatically disable the on-board if a PCIe card is installed?
I'd say that if you're only planning to use the PCIe card, you'd be better off uninstalling the drivers first and then re-installing them when you boot with the new card installed.
Old March 30, 2007, 03:27 PM
Supergrover's Avatar
I always use driver cleaner when I update my drivers, I wouldnt run both disable your onboard in the bios anfter you remove the drivers......
I dont like posting links to other sites but Here is a great easy to follow guide.
R.I.P.
Old April 2, 2007, 02:18 PM
ragenrok's Avatar
lol thanks for the link. I never thought of disabling the on-board card in the bios, ill do that as soon as i get home. I installed the 8800 in my comp and it works just fantastic, im very impressed with it lol, but im gonna disable the on board just incase.
Old April 2, 2007, 04:12 PM
Patriote's Avatar
Yeah your better off to disable it just in case. And also, you should install new and latest drivers for that card. You'll have to either use driver cleaner after uninstalling the old Nvidia drivers or install a fresh copy of windows and get all the latest drivers for your hardware.
Just my 2 cent. (PS: We need a 2 cent image or something )
- Asus P8Z68-V PRO
- Intel I5 2500k @ 4.5Ghz
- Asus Geforce 580GTX DirectCUII Fermi
- 16GB Corsair Vengeance Low Profile
- Ultra X3 1000 Watt
- Asus Xonar DX 7.1 \ Klipsch Promedia 2.1 THX
- Corsair Vengeance 1300 Gaming Headset
- Crucial M4 SSD 128GB \ WD Caviar Black 1TB
- CoolerMaster 690II Advanced
- Dell UltraSharp 24''
- Noctua NH-D14
Old April 3, 2007, 09:42 AM
ragenrok's Avatar
lol, I made sure to run driver cleaner and install the new drivers already, twas the first thing i did after my comp booted up. but thanks for the 2 cents
8800GTX drivers magictorch Video Cards 4 September 17, 2007 04:31 PM
Anyone tried the new drivers yet? ragenrok Video Cards 2 May 17, 2007 04:35 AM
64 bit drivers don'tknowmuch O/S's, Drivers & General Software 1 March 19, 2007 05:37 AM
Best Drivers r0k0 Video Cards 3 March 15, 2007 08:53 PM
Vista drivers UNESCO Video Cards 4 November 29, 2006 11:55 PM
