-   -   Dual Monitor on 9800 pro (http://www.hardwarecanucks.com/forum/video-cards/7521-dual-monitor-9800-pro.html)
ebdoradz May 27, 2008 05:06 PM
Hey, i just bought 2 17'' LCD monitor for 60$ each used, im trying to setup the dual monitor on my blue rig and i can have some trouble with the dual screen
the windows bar does not disply on both LCD,
and everything open in the 1st screen while i have to drag and drop in to the 2nd one to make thing display in the 2nd screen
any idea
im u sing Omega driver, and one screen is directlyu to the VGa port and the other one is plug into a DVi to VGA adaptor to have the LCD plug via vga
darksideleader May 27, 2008 06:05 PM
um i think thats normal? I've use dual monitors on my older socket a system for awhile, the task bar was always only on the 1st monitor and windows always start on the first monitor, i drag to 2nd monitor.
Is it different with your other comps? try those.
JD May 27, 2008 07:11 PM
If you have the option, I think you want horizontal span mode or something along those lines. Then it will basically stretch your desktop across both screens.
Phobia May 27, 2008 09:17 PM
yes, as the people above posted, you need to get into horizontal span mode. Right now, you have just checked "extend my desktop to this monitor" button. I use ntune to put it to horizontal, but i do not remember if theres an easier way.
enaberif May 28, 2008 12:07 AM
taskbar will only span across two screens using something like Ultramon.
ebdoradz May 28, 2008 04:38 PM
ok, thnaks guys, its the 1st time im trying dual monitor so i was wondering if that was normal or not ...
i had already seen ppl with windows bar on both screen thats why i have asked
