Old November 26, 2016, 02:43 PM
Default GTX 980 vs GTX 1060
Helping put together a system for a friend and have the choice of a EVGA GTX 980 Classified and Gigabyte GTX 1060 Extreme. Opinions on which to go with? Will be mainly Gaming at 1080 with possible upgrade to 1440.
Old November 26, 2016, 09:35 PM
Coach's Avatar
I own an MSI 980 Gaming 4G and an EVGA 1060 SC 6GB. I would get the 1060 6GB. More vram, less power and better architecture. Other than that they perform about the same. FWIW they are used with 1440P displays.
Old November 27, 2016, 12:55 PM
https://i2.wp.com/www.babeltechrevie...y-OC-chart.jpg
That covers a lot of ground ^. At 1440 the GTX980 looks a little better but it depends on what games that he'd be playing.
I really don't like the 192bit trend in general.
Gaming FX 8350 4.4GHZ / Tuniq Tower 120/ MSI GTX 1070 Armor / G Skill 32GB / S12D 850w/ GA 990FXA-UD3 /SSD 240GB , WD1TB FALS, 3TB Toshiba / Dell IPS 1920x1080/ Win 10 64
Daily Use FX8350 Stock GHZ/GA 970 Gaming/ Rx 580 8GB /EA750w/4x4GB ram/Win 10 64 and 24TB of hdds
Old November 28, 2016, 07:05 AM
Dark Knight's Avatar
Using HWBench as a comparison here:
GeForce GTX 1060 vs GeForce GTX 980
We can see that the performance is within a few percentage of each other. The difference is primarily architecture, vram and power consumption as Coach has mentioned.
Old November 28, 2016, 08:35 AM
Rye 1080's Avatar
They are basically equal performance wise. Slight edge to the 1060 6GB in DX12.
Old November 29, 2016, 03:52 AM
Decided to go with the 1060. May as well go with the newer product.
Old November 30, 2016, 06:42 AM
MARSTG's Avatar
Me too, exactly the same thinking.
Old December 13, 2016, 10:46 AM
I will prefer the new card every time. Since i watched so many reviews there is no doubt. This card is going to be better and better than gtx 980 because of driver updates. 980 will be forgotten very soon:( Same thing with my gtx 780. So 1060 is the choice.
1080P Gaming, 470 4GB or 1060 3GB?? Coach Video Cards 10 October 29, 2016 07:49 AM
GTX 1060 6GB vs GTX 1060 3GB MARSTG Video Cards 7 September 11, 2016 01:05 PM
Dear Nvidia, concerning the GTX 1060 3GB Coach Video Cards 12 August 22, 2016 06:44 AM
1600 MHz on a 1060 MHz supported CPU Armored RAM 2 September 20, 2011 07:04 PM
