| i'm a bit outdated on vidcards, where's x1950xt at now? does it still worth $200? Radeon X1950XT PCI-E DDR3 256-bit Bandwidth 37.1 GB/s GPU Clock 500 MHz Memory Size 256 MB Transistors 384 million Process Technology 90 nm RAMDAC Clock 400 MHz Pixel Pipelines 16 Vertex Shaders 8 (v3.0) Pixel Shaders 48 (v3.0) Pixel Fillrate 8000 MPixel/s Texel Fillrate 8000 MTexel/s |
| I would not spend more than $100 on a x1950XT. In all seriousness it wouldn't even be worth that.
__________________ essentials: Intel E8400 - eVGA 780i - Galaxy 8800GT SLI - 4GB Patriot Viper PC2-8500 storage: (3) WD6400AAKS - Dell Perc5/i RAID5 case & power: Tagan Black Pearl [under construction] - Gigabyte Odin GT - Silverstone CMD01-ESA cooling: DTEK Fuzion - (2) Swiftech MCW60 - Swiftech MCP355 w/ EK X-150 - Koolance Compression Fittings - Feser One Tubing |
| You can just stick a passive cooler on yourself. Just grab a 9600GT and the Arctic Cooling Accelero S1 Rev. 2. It should still be cheaper than a X1950XTX, and a ton better. This is the heatsink: Arctic Cooling
__________________ X3350 @ 3.4GHz | DFI LanParty LT X38-T2R 2x2GB Dominator @ 1062MHz| VisionTek 4870 @ ?/? 3*160GB RAID5 + 320GB | PCP&C 750W Silencer | HT Omega Claro Sennheiser HD280Pros | Zalman Mic | Modded CM Stacker STC-T01 |
| You can get a 3850 for $99 these days, don't waste your time with 19xx
__________________ Mobo: DFI 790X-M2R Proc: AMD PHENOM X4 9850 Ram: OCZ Platinum 2X 2GB @ 1066 VIDEO: 3 x Visiontek HD3870 @ 900/1300, hard-modded |
| I sold my 10-month old ASUS X1950 Pro to a friend for $100 on February. But I also upgraded her PC (mobo+cpu+psu+mem) for no charge. So I guess that's sort of the payment. I got to keep the rebates too :). |
| Thread Tools | Search this Thread |
| Display Modes | |
