Old January 19, 2015, 12:53 PM
Default coil whine an acceptable rma?
both my 280x's are now having some pretty bad coil whine. been running them pretty hard but i am wondering if this is something i can and should rma or would this lead to hassle's?
Old January 19, 2015, 01:20 PM
Conformal coating on the coils should clear it up.
Mah Rig now
Mah Rig before
My stuff for sale.
Old January 19, 2015, 03:23 PM
ty sir
Old January 19, 2015, 05:28 PM
Dzzope's Avatar
Depends on the company. Some will, some not. If you want to you need to contact them. And make sure it's not the PSU (something I've found in many machines where people think it's the GPU).
Random quotes:
AKG: "So please don't piss on people and claim its raining. "
Soullessone21: "Their the only fat bitches I ever want in my wife :)"
DeeraxTheCoolNemo: "I never preSs CaPLoCK I just HiT my keyS so Hard ThEY Crit"
Old January 26, 2015, 03:36 AM
sf101's Avatar
Ive heard hot glue on coil will sometimes also dampen it.
The problem is this.
If they wont RMA for coil whine.
And you do modify it with conformal or gluegun.
And then you do have a real RMA worthy failure it better come off easy or they will jerk you around over modifications.
I had a board once that I put a CPU into which was from another setup i used to go cold with so it had a bit of vaseline on it not much but trace amounts on the edges, and the Mobo failed due to a bios failure it would boot in secondary bios but not flashable and was getting worse.
Asrock Jerked me around because they found a dab of residue from the vasoline on that cpu socket not even in the pins just the corner of the plastic where its keyed because i didnt rub it off my cpu properly before switching it.
The funny thing was it ran for 6 months before issues.
Now that board never even got the vaseline treatment because it was just a gaming machine but it nearly cost me warranty and they argued with me over it for 2 weeks before yielding and i think the only reason they yielded was because the 2ndary bios was working and probably to their dismay tested by their 3rd party dealer before he sent it too them which was documented.
If it had been a full hardware failure likely they would have just laughed at me.
New mobo has been working since no issues with the same CPU although i cleaned it up a bit better this time before intalling it.
My 5 Current Rigs-Guest-Main-Work/Spare-HTPC-Laptop
I7-6700T-Work
3770K@ 4.8GHz -Main
2500k @ 4.7GHz -Guest PC
3570K @ 4.5 -HTPC
MSI GT70-2OC/770m-998/4800MHz -Laptop
SF101 HW BOT
Crossfired XFX290X@1150/1500mhz-EKWB (Main)|GIGA-OC7970WF3@1250/1850 (HTPC)
MSI 970GTX (Guest) ||Asus480GTX@900/2000 (work)
Old January 27, 2015, 09:28 PM
Icarus's Avatar
I returned a card for coil whine so loud I could hear it at the bottom of the stairs!
There is no way a card touted as being quiet (esp the ones with 0db no fan at idle) should be considered acceptable with coil whine.
Ϣr
i7 4790k 32GB Kingston HyperX MSI Gaming 5 MSI R9 390X Gaming 8G 30" HP ZR30W + 27" Samsung 275T 4x240GB Intel 530 in Raid 0 + 1TB WD Black Lain-Li X2000F EVGA SuperNova 850W G2 BeQuiet! Dark Rock 3 Logitech Z5500 Win7pro 64bit
Old January 27, 2015, 09:59 PM
conformal coating is certified to protect electronics from all kinds of things. Moisture mainly... it won't harm anything.
Mah Rig now
Mah Rig before
My stuff for sale.
Old January 31, 2015, 08:59 PM
Icarus's Avatar
That will only work on an open style coil, not the covered ones like on most cards now a days.
Ϣr
Old February 3, 2015, 12:21 AM
THS THS is offline
Agreed with above. Try RMA. If that doesn't work, try conformal spray but it might not work if coils are covered.
Video card screetch/whine (Coil Whine?) Randylahey Video Cards 12 January 10, 2014 09:25 AM
MSI 7950 coil whine Messerschmitt Video Cards 3 August 30, 2013 10:04 PM
PSU Coil whine ? Kilauea Power Supplies 9 April 3, 2011 07:24 PM
Overclock to get rid of coil whine? Technokat Video Cards 0 December 2, 2009 01:35 PM
coil whine issues (pic) lexmark1 Power Supplies 11 May 29, 2009 07:19 AM
