Old December 23, 2014, 08:01 PM
Default GTX970 (onboard RAM not being used)
I put together a new computer, and installed an ASUS GeForce GTX970 (4GB RAM) in the only PCIe slot on my mini-ITX card, and connected the secondary power cable. Installed the most recent nVidia drivers and the card shows in the Device Manager. Everything looked good.
Installed a couple of games to test out the card. Didn't notice any difference between the display on this machine and the same games on my older computer. Also got an "out of memory" message at one point. I began to poke around and discovered that the games were using System RAM and not the RAM on the video card. I was surprised because the GTX fans would start up during game play, which made me think everything was okay. Talked to Memory Express and they said to bring it back for replacement. But, this being my first build, I thought maybe I skipped a step during the installation of the card.
Here are a couple of screenshots.
Does anyone have an idea as to what's going on?
Old December 23, 2014, 08:04 PM
Bond007's Avatar
Are you connected to one of the display ports on the motherboard, or on the graphics card?
Desktop: Arc Midi R2, Z77-D3H, 3770@4.1ghz with Zalman Optima Cooler, 4x4gb ram, EVGA GTX 1070 Ti SC, Bitfenix Fury 750w, WD Black 1TB, MX500 500gb
Away from home: Lenovo Legion Y530, 16gb, i7 8750H, GTX1050Ti
Old December 23, 2014, 08:25 PM
lowfat's Avatar
I assume you are using the newest Nvidia drivers? Try doing a clean installation of the drivers.
Also check VRAM usage an application like EVGA PrecisionX or MSI Afterburner.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old December 23, 2014, 09:11 PM
Connected properly to the video card.
Device Manager says the card is working properly and drivers installed.
Just did a re-install of latest drivers, but no change.
I'll look up those apps right away. Thanks.
Old December 23, 2014, 09:34 PM
Try taking out 4g of ram. You have a 32bit OS, they extra 4g of ram maybe messing up the memory management.
Old December 24, 2014, 04:55 AM
Bond007's Avatar
I just saw that as well... The pictures weren't showing up on my phone. You chose a 32bit version of windows, so you will never be able to have more than 3.xx GB ram.
Old December 24, 2014, 06:03 AM
Your video card is probably fine; only way to fix this is to reinstall with a x64 OS. A 32 bit OS can only reference 3.xx GB of memory COMBINED (2^32, whatever that number is) - including the system memory, video card memory, peripheral and any other type of memory the build contains. PAE may help a bit, but it will be bit slower. Plus you're going to run into issues where newer games require an x64 OS to run; there are already a few of these floating around.
GTX970 owners discussion On2wheels Video Cards 7 May 28, 2015 09:27 PM
[WTB] GTX970 Solace Buy/Sell & Trade 1 September 22, 2014 07:02 PM
Onboard GPU nasrott CPU's and Motherboards 7 January 18, 2013 05:16 AM
Onboard for HTPC? 3 of 7 Video Cards 19 August 4, 2009 07:20 PM
DGE-530T vs Onboard TopDogZero Networking 1 July 30, 2009 03:26 PM
