Old December 12, 2014, 10:33 AM
Dzzope's Avatar
That case will be fine.. Stick a fan on the side with some mesh to stop dust (cut up some stockings is an easy way)
PSU, I'm with the above also.. even a cheap but decent PSU is worth getting to protect the card alone, nevermind the rest of the rig. Make sure whatever your picking has had a professional review done of it... if you can't find one then it's probably not worth getting.
On the cpu, Agree with the above, watch some vids, it's pretty easy to do, just the next logical step.
When re-applying thermal paste, wipe off the old, use a small, pea sized, blob in middle of CPU and then place the cooler.
I tend to lift mine to make sure it's covering the whole cpu (if not add a tiny bit to the area not covered)
Your looking to get the best coverage with as little paste as possible for best results.
For overclocking, there are plenty of guids and youtube video's out there.. Just make sure you understand the settings your changing and what is a safe setting for it.
Then run a stress test, confirm stability at what is considered a reasonable 24/7 OC and your done.
It's a bit of work and research but well worth it if your not looking to / can't afford to upgrade.
Random quotes:
AKG: "So please don't piss on people and claim its raining. "
Soullessone21: "Their the only fat bitches I ever want in my wife :)"
DeeraxTheCoolNemo: "I never preSs CaPLoCK I just HiT my keyS so Hard ThEY Crit"
Old December 12, 2014, 11:37 AM
Thank you all, guys!
In the end I bought This PSU and the Asus.
I'll search and buy some thermal paste, and change it when I'll mount the rest. I knew about the stocking trick, but in my experience, the static of the nylon ends up attracting even more dust forcing you to vacuum clean it every other day to prevent it to plug shut...
Thanks again a lot everyone!
Old December 21, 2014, 06:08 AM
MARSTG's Avatar
Cheapest prices in Europe for hardware are in France at RueMontagallet.com. GTX 970 is not under 300 Euro but above. The cheapest one I saw was 296, a PNY 4 GB on a promotion at Pixmania.fr. From what I have seen they also have a branch in France that is close to Italy. But they also have branches in Italy, where the price for that card is just a bit higher at 309 Euro. PNY Scheda grafica GeForce GTX 970 Enthusiast Edition - 4 GB GDDR5 - PCI Express 3.0 | Pixmania
Tags
970 , best brand , nvidia
Going to be buying a 6xx series Nvidia. Which brand? Pabz0r545 Video Cards 17 March 28, 2012 08:02 AM
Company Seeks Export Ban of Apple’s iPads Sam_Reynolds Press Releases & Tech News 20 February 16, 2012 06:33 AM
noob help for i7-860 OC Sandro_Bit Overclocking, Tweaking and Benchmarking 2 September 24, 2009 01:40 PM
HTPC Noobie Seeks Advice dadzilla HTPC Systems & Software 3 October 2, 2008 03:32 PM
HardwareZone has Nvidia GeForce 8800 GTX buying guide & shootout Supergrover Reviews & Articles from the Web 0 December 14, 2006 07:04 PM
