Old May 11, 2008, 08:04 PM
Eldonko's Avatar
Hardware Canucks Reviewer
Life of beta drivers :)
Old May 11, 2008, 08:06 PM
sswilson's Avatar
Originally Posted by Eldonko View Post
I loaded these drivers and now I cant even get into Windows. I tried everything and all I can do about it is format and reinstall.
What are you running? It'd be nice to know just in case somebody else has a similar setup so that they can avoid the same fate. Did you by any chance have something like Riva Tuner setup to load a custom config on startup?
Old May 11, 2008, 08:32 PM
Eagle Eye's Avatar
Did you try safe mode at all to see if you could uninstall them?
I had no problems with the installation or loading windowsXP MCE SP3.
Old May 12, 2008, 08:31 AM
Eldonko's Avatar
Here is the story. I loaded these drivers and rebooted. Windows would go as far as the loading Windows screen and then bsod in a neverending loop. I could not access safe mode bc my stupid usb keyboard would work as far as the bios then nothing on the safe mode screen. But I sawpped to ps2 and loaded last bootable config. Uninstalled the drivers and reloaded latest (non-beta) from Nvidia. All fixed.
GPU = 8600GT
Old May 12, 2008, 11:13 AM
Eagle Eye's Avatar
Good to hear that you didn't have to format I know how much of headache it can be, something that I try to avoid at all cost.
Old May 12, 2008, 11:16 AM
Eldonko's Avatar
I run so much different hardware that formatting is no big deal, usually do it a couple times a month anyway. :)
