Old September 26, 2014, 05:24 PM
Default Problem with my GPU
Hi guys!
I'm having trouble with my new GPU (R9 280x). Long story short. Last month I bought the GPU, but couldn't use it because I had a shitty PSU. So today I bought a new PSU (Antec High Current Gamer 750w) and I connected the new GPU. First boot is ok, used to have catalyst, so no big deal about drivers. But when I opened a game it crashed before it even started.
Then I restarted the PC, but I couldn't boot past windows 8 logo. When Windows 8 user password screen should come, my screens starts blinking.
I tried using the onboard gpu, and everything is fine. Tried uninstalling AMD drivers, but got same results. Don't know what else to try!
Old September 26, 2014, 06:14 PM
TTC TTC is offline
You sure its seated correctly in the slot? You have both plugs in to power it?
Old September 26, 2014, 06:42 PM
Bond007's Avatar
Uninstall all video drivers, run driver sweeper to clean any remaining. Reinstall drivers.
Sounds like a driver issue.
Otherwise you could try a clean install of windows.
Old September 26, 2014, 08:45 PM
Solved! Was driver problem.. had to uninstall in safe mode, thx anyways for your help!
Could a hardware problem cause a driver problem? LaughingCrow Troubleshooting 4 January 19, 2012 11:46 AM
Steam connection problem (Problem Fixed) great_big_abyss Gaming 3 January 10, 2012 05:37 PM
Hard drive problem or Windows 7 Problem?! aeminence New Builds 4 October 13, 2011 06:46 AM
could this be a game problem or a video driver problem? Shadowmeph Troubleshooting 4 December 17, 2010 07:01 AM
Hardware problem or HAL problem? andynerd Troubleshooting 1 March 7, 2009 09:03 PM
