Old May 26, 2014, 08:31 PM
SKYMTL's Avatar
HardwareCanuck Review Editor
Default Sapphire R9 290 Vapor-X OC Review Comment Thread
Sapphire's R9 290 Vapor-X OC is not only one of the highest-clocked R9 290 cards around but it also boasts some of the highest overclocking headroom we've come across in a long time.
Read more here: Sapphire R9 290 Vapor-X OC Review
Old May 26, 2014, 09:55 PM
sf101's Avatar
amazing clocks.. im surprised at those clocks the results weren't higher was it throttling at times? or was power % limit not maxed out?
My 5 Current Rigs-Guest-Main-Work/Spare-HTPC-Laptop
I7930@4.0GHz-Guest
3770K@ 4.8GHz -Main
2500k @ 4.7GHz -work/Spare
3570K @ 4.5 -HTPC
MSI GT70-2OC/770m-998/4800MHz -Laptop
SF101 HW BOT
GPU's ("xfire"2x XFX290X@1150/1500"EKWB"|GIGAOC7970WF3@1250/1850|Asus480GTX@900/2000|
2xEvga260Core216's SLI in HTPC-Retired gpu's 9600ati|9800proATI|8800GTS"320mb&640mb"
|8800GTX|9800GT|9800GX2
Old May 27, 2014, 01:53 AM
IRQ Conflict's Avatar
I think what has happened is that when AMD figured out how to tame their frame times in the driver it brought the max FPS down a notch or two. It's fine by me as long as the minimum FPS don't go to low.
Old May 27, 2014, 04:50 AM
SKYMTL's Avatar
I was expecting higher performance as well with the overclocks BUT, there comes a point when the architecture becomes more of a bottleneck and increasing clock speeds yields limited returns. Unlike popular belief, clock speeds and perf don't scale in a linear fashion. For example, a 10% clock speed bump won't result in 10% better framerates.
Clocks were sitting at 1280 the whole time according to GPU-Z with only a few dips. (See edit)
Old May 27, 2014, 11:38 AM
Does this card match a reference PCB like the original Sapphire Tri-X 290? I recognize the changes to length but without a PCB picture wonder if any reference waterblocks will still fit it for future builds.
sf101's Avatar
rgr see the same thing when benching all the time diminishing returns on ocing.
Threw me off is all since most 290x's @ 1200 or so pull ahead of stock 780TI in other reviews i've read and this 290 from sapphire has a hell of a oc @ 1380mhz i expected it to stomp all over a 290x @ even 1250mhz.
Also threw me off it didnt even break 60fps but i guess it got close.. have you tried Mantel on those 2 benches? perhaps including mantel results would be a neat to see compared to dx11.
I7930@4.0GHz-Guest
3770K@ 4.8GHz -Main
3570K @ 4.5 -HTPC
SF101 HW BOT
Old May 27, 2014, 12:56 PM
SKYMTL's Avatar
Completely custom PCB and VERY hard thermal compound so I couldn't remove.
Old May 28, 2014, 02:51 AM
Dzzope's Avatar
Hit it with a brick :D
Random quotes:
AKG: "So please don't piss on people and claim its raining. "
Soullessone21: "Their the only fat bitches I ever want in my wife :)"
Old May 28, 2014, 05:14 AM
Heat it in the oven, then hit it with a brick.
Old May 28, 2014, 05:45 AM
SKYMTL's Avatar
HA! Unfortunately, this one was a loaner. So no bricking, stoning, heating, smashing or licking.
Sapphire R9 290 4GB TRI-X OC Review Comment Thread SKYMTL Video Cards 35 January 29, 2014 03:53 PM
Sapphire HD 5750 Vapor-X Review Comment Thread SKYMTL Video Cards 12 May 12, 2010 12:28 PM
Comment Thread for Sapphire HD 5970 2GB OC Review SKYMTL Video Cards 78 March 8, 2010 07:31 PM
Sapphire HD 5870 Vapor-X 1GB Review Comment Thread SKYMTL Video Cards 24 November 9, 2009 01:50 PM
Sapphire HD 4890 2GB Vapor-X Review Comment Thread SKYMTL Video Cards 12 September 21, 2009 08:20 PM
