Old May 3, 2008, 09:48 PM
Default 8800GT vs. 8800GT AKIMBO SC?
I was curious about the difference between the two cards. The stock 8800GT (512) is 600/1500/900, and runs at ~90C when active. The AKIMBO SCversion is 720/1500/2000, with a better cooler that gets typically 20-30C cooler than the stock one.
Judging by this: Is the 8800GT AKIMBO SC basically a factory OC'ed 8800GT with a dual-slot cooler to allow for the OC? If so, would I be better off getting a normal 8800GT, OCing it, and then get a thermalright, AC, or even the actual AKIMBO cooler the way ipaine did?
I am thinking mainly in terms of total price vs. performance vs. temp, but I am not quite sure. Any pointers on this would be greatly appreciated. Thank-you!
Old May 3, 2008, 09:53 PM
sswilson's Avatar
Yes, it's basically a better cooled reference design 8800GT with a pre-oc'd modded bios.
Depending what kind of money you are planning to spend, you might also want to look at some of the 8800GTS (512) deals currently available.
Old May 3, 2008, 10:13 PM
The absolute highest I am going is $250, lets see prices on directcanada as of now...
8800GT 512: $182
AKIMBO SC: $200
8800GTS 512: $240
And we already know 8800GT and AKIMBO SC speeds, so the GTS 512's are: 670/1674/1940, 128 stream processors...
Well, fairly evenly matched, of course the GTS 512 has the most performance.. but the AKIMBO is on sale... Which would you suggest>?
Old May 3, 2008, 10:36 PM
sswilson's Avatar
I just picked up a gigabyte 8800GTS so I'm a bit biased.... :)
I'd say go for the GTS if you can swing the money. Stock speeds on the GTS will more than likely perform better than the OC'd 8800GT, so you'll get a major boost from an OC'd GTS.
Old May 3, 2008, 10:50 PM
Well, let's hear it, how is GTS working out for you? :)
As a point of curiosity, is the GTS good for Tri-SLI, because I am ordering a 780i, and I wouldn't want it to go to waste. Perhaps I should just wait for the 9800GTS or GT. AGH! Now it's a question of patience, I guess...one last tip please, what would you do>?
Old May 3, 2008, 11:09 PM
sswilson's Avatar
I'm not up on what's going to be required to run tri-sli so I can't comment on that at all.
You can have a look at the mini-review I did over at NCIX for my new card http://www.ncix.com/products/index.p...cture=Gigabyte (second from the top I think).
My comparison was to a 3870, but with a 2000+ `06 improvement over it, you can be fairly certain that it'd post at least 1500+ better than an 8800GT.
Old May 3, 2008, 11:17 PM
Cool, thanks for the help. I have decided to wait until july to see the 9800GT and GTS, becasue I don't think there is a point in buying an 8 series for now when the 9 series is right around the corner. I am leaning toward the GTS because of the added performance and OC capablility, But if the 9800GTS or even GT is good enough to go on with a price that fits, I'll take that any day.
Thank-you very much!
Old May 4, 2008, 08:21 AM
ipaine's Avatar
Well since you decided to wait not sure what my opinion is worth. But I'm going to give it anyways.
I have to agree with sswilson about getting the GTS. I know if I could have gotten the GTS for a good price I would have. Of course I do not regret getting the 8800GT and now have 2 of them so I'm sure I'm getting better fps than a single GTS but then I did pay more.
I really can't blame you for waiting at all. I know that I will be looking at the 98xx's or 99xx's as a possible step up. Well if they show up in time that is (and if I can convince my wife).
"Nothing sucks more than that moment during an argument when you realize you're wrong."
