EVGA | EVGA Precision
I just downloaded the EVGA GPU overclocking utility to try it out-
It's pretty simple and easy to use- not nearly as many functions as RivaTuner at first glance. It's got a testing utility, but it doesn't work with my 8800GTS. It also has a simple fan speed slider for those non-watercooled peasants
I've played a couple of games and things are stable and the OC has stuck on reboot. All in all it seems like a good, simple to use tuner so far but it's only been a couple of hours.
Turn off your RivaTuner OC before you download and install it or you'll run into some minor glitches.
