Old May 27, 2008, 06:11 PM
darksideleader's Avatar
Originally Posted by Kaizer Soze View Post
If they put that much memory into a 9600 GT or 8800GT it might have a bit of an advantage, but if you put it on something like a 9600GSO with 192bit interface, it is a complete and utter waste of silicon.
nah... not really even crysis manages to use 750mb the most out of your videocard. MSI recently made a 2GB 9600GT. Tons of 8800GT/GTS with 1GB of memory and even 3870/3850.
There are some 8500GT's and 8600GT's with 1GB of memory. there are people who think more is better. (either their misimformed or still stuck in the 8mb vs. 16mb videocard times. But of course they shouldn't target these videocards to gamers....
Old May 28, 2008, 09:41 PM
Well...call me a n00b, but up to a certain point (1536MB for 9600GSO and 2G for 9800GT are just mental ) there must be some advantage to having 1G on cards like 8800GT. If Crysis uses only ~750MB of your graphics card memory, then it would be an advantage to have 1G over the decent 512MB and not-so-great 256MB, siince the game will be able to utilize all the memory it can, and have some space left over, there is no big deal. However, if you have 1536MB-2G of memory, the game will only be utilizing half or less of all the avaliable memory, THEN it will be a waste. Like I said, that's just me, you may call me a n00b now
Old May 29, 2008, 09:02 PM
Eagle Eye's Avatar
Its far more complicated then you think Kaizer and by any means we are all noobs when it comes to understanding how a games utilizes the GDDR available. From what I have read there are many determining factors that affect how a game will utilize the available frame buffer. I won't go into to great detail simply beacuse I don't know enough yet or understand it all, but some things to take into consideration are the memory interface ie. bitrate (384bit, 256bit and 192bit), driver optimization and texture size. Simply the excidingly amount of memory the card comes with is by no means a measurement of performance, in the end its all about marketing and apealling to those that haven't the first clue about video cards.
Old May 29, 2008, 09:31 PM
donimo's Avatar
Hmmm, I wonder if I can cancel my order...
Mobo GA-Z77X-UD3 CPU i5-3570K stock RAM:2x4GB Patriot Viper 1866 1.5v GPU:XFX HD6850 BE + Gigabyte HD6850 @820/4400MHz Case:Bitfenix Raider w/2x 200mm + 135mm PSU: Corsair HX620
Old May 30, 2008, 01:11 AM
MpG's Avatar
MpG MpG is offline
The only game I've ever seen that is capable of using all the memory on a 8800 GTX (768MB) is Oblivion. Wish I could remember where the review was, but in a comparison between the standard 2900XT and the 1 GB version put out by Diamond, with all clocks equal, the 1GB was pulling ahead at max settings outdoors. Not to say that either was actually playable, but the difference was definitely documented. Even a GPU-killer like Crysis, if I'm not mistaken, only needs about 300-400MB of video RAM at high settings.
Old May 30, 2008, 07:15 PM
..'Ant'..'s Avatar
With only 192-bit interface and with 1GB = Useless.
