Old March 31, 2014, 06:43 AM
Bojamijams's Avatar
Default Issues with R9 290 in crossfire on a P67 mobo
Is anyone here running this configuration successfully?
I get higher scores in crossfire vs single gpu on 3d mark and any benchmark program, but if I try them in games (BF4, Planetary Annihilation, Skyrim) I get no increase over single GPU and possibly even a decrease. If I look at the usage, I can see the usage goes from 0 to 100% alternating on the cards and makes this see-saw pattern that it does not do on artificial benchmarks.
I'm running them in pci-e 2.0 x8/x8mode , latest BIOS, 14.2 drivers, but I'm wondering if something is preventing them from working fully. The 2.0 x8/x8 shouldn't be a limitation on bandwidth because it would also affect the benchmarks so something else must be going on.
Is there a way to make sure that ULPS is disabled permanently? (I did the registry change but I don't know if it 'sticks').
Is there any other settings/functionality like ULPS that could affect crossfire in games?
Thanks for any suggestions.
Computer: i7 2600k @ 4.7Ghz | Asus P8P67 Evo | Corsair LP 16gb 1600CL9 | Silver Arrow | Essence STX | Crucial m4 128gb | Silverstone Raven 3|
Video: 2x R9 290 @ 1050 / 1375 | ASUS VG248QE |
Audio: STX => Audioengine A5 / audio technica AD700X
Old March 31, 2014, 07:39 AM
Arinoth's Avatar
What operating system are you running?
Here I am: here I remain
Old March 31, 2014, 07:49 AM
Bond007's Avatar
It definetely should run fine in x8/x8. I will let someone more familiar with crossfire walk you through any required settings to get it running properly. Sounds like a settings issue.
Old March 31, 2014, 07:58 AM
Bojamijams's Avatar
Sorry, should've listed that.
Windows 8.1 x64
Bojamijams's Avatar
How do you guys make sure ULPS is disabled in crossfire mode?
Old March 31, 2014, 08:16 AM
Arinoth's Avatar
Make sure you have this checked off, just in case (Ignore that it says AMD FirePro, it was a quick Google search for the image, for you it should be under Performance aspect):
Also, try out the 14.3 Beta Catalyst drivers too.
Old March 31, 2014, 08:35 AM
I hope this is helpful.. But i'm not sure if you are looking for max fps increase.. If so and you are not seeing it, make sure VSYNC is disabled in your games.
http://www.mowatsparty.com
Old March 31, 2014, 08:58 AM
Bojamijams's Avatar
Arinoth: Yeah that checkbox is there.
Also I've tried with VSync on and Off. Neither really stops the 0% to 100% to 0% issue.
Old March 31, 2014, 09:01 AM
Arinoth's Avatar
Hmm, I'm trying to think of something else you can try, I'm limited in what I can recommend due to internal methods that I can't share.
Old March 31, 2014, 09:28 AM
Bojamijams's Avatar
I will try to disable ULPS another way. I don't like Trixx but I hear the beta version of Afterburner has it so I will try with that. Maybe the way I disable in registry vs how Afterburner does it is different. It really sounds like ULPS the more I think about it.
mobo issues drkrazyrich Troubleshooting 7 December 3, 2012 05:32 PM
Crossfire doubt... will my mobo support it? unnAMD CPU's and Motherboards 0 June 23, 2012 12:06 AM
ASUS mobo flashed bios issues. Ov3rTheTop CPU's and Motherboards 2 May 8, 2012 05:25 AM
[WTB] Crossfire Mobo for a Quad core 9850 BE norfolk Buy/Sell & Trade 0 March 29, 2009 09:55 AM
