<~----> What can your ATI Do? - Hardware Canucks
Old March 21, 2007, 12:32 PM
BALISTX's Avatar
Default What can your ATI Do?
I decided to run some test with my ATI All-in-Wonder 9800 Pro with 3DMark05 and here are the results I got.
Test Setup
AMD Athlon XP 3000+ @ 2.2GHz
ATI All-in-Wonder Radeon 9800 Pro 128MB
1GB Micron PC2700 DDR 333MHz 2.5-3-3-7(2x512MB)
Windows XP SP1
DirectX 9.0c
Driver ati2dvag.dll (8-2-2006)
As you can see by the results that it didn't fair out too well. Safe to say running any AA even at 2x would of brought it to it's knees.
Here are my Temp Specs on my CPU while before and after running the tests.
CPU Temp Idle: 42°C
CPU Temp Load: 63°C
CPU Fan Speed: 3375rpm
Case Fan Speed: 1318rpm
"Though I walk through the shadow of the Valley of Death I shall fear no evil as my C8 Carbine is locked and loaded."
Next Build: E5200 @ 3.6GHz (333x11) | Xigmatek HDT-RS1283 HSF | Biostar TP43D2-A7 | Mushkin Redlines DDR2-1000 @ DDR2-999 5-5-5-12
EVGA 9600 GT 512MB - 650MHz - 1800MHz - 1626MHz | Seagate 'Cuda 250GB 7200rpm SATA2 | Corsair VX550 | CM690 - Custom Atomic Orange Pearl
[Heatware]
[eBay]
[Rosetta]
BALISTX.com
Old March 21, 2007, 01:40 PM
A friend of mine has one like yours and he does quite well with it in COD2 in DX7...gets about 200fps with an Athlon 64 3800X2. I'll see what he gets in 3dmark2005
Old March 21, 2007, 02:26 PM
Gav's Avatar
Gav Gav is offline
Administrator
Originally Posted by K1LLER_INSTINCT View Post
Test 1 was done at 640x480 No AA
[img=http://imageshack.us/thumbnmail.png]
Test 2 was done at 800x600 No AA
Test 3 was done at 1024x768 No AA
[img=http://img339.imageshack.us/img339/5835/1024x768jz7.th.gif]
Just a note we don't mind hosting images here. You can either upload attachments and then insert them using the attachment button or you can try out the new VB Image Host feature that we have installed in the navbar link.
Old March 21, 2007, 02:46 PM
BALISTX's Avatar
Thanks Gav. It's uploaded
[Heatware]
[eBay]
[Rosetta]
BALISTX.com
