Old February 27, 2014, 10:59 AM
Default EVGA GTX 660 Ti 3gb or msi N760 GAMING GeForce GTX 760 4GB
I'm looking at upgrading my video card my choices are EVGA GTX 660 Ti 3gb($339.99) or msi N760 GAMING GeForce GTX 760 4GB ($359.99). Any opinions on which might be better?
Thanks for any ideas.
Old February 27, 2014, 11:42 AM
10e's Avatar
10e 10e is offline
For gaming the 760 is probably a better performer especially at higher resolutions due to it's 256 bit memory bus, whereas the 660TI uses a 192 bit memory bus. For $20.00 it's a better deal. The only better spec on the 660ti is the larger number of shaders but that is generally moot for gaming. The extra memory on the 660ti is basically rendered semi-useless because it comes into play at higher resolutions where the card is somewhat hamstrung.
Old February 27, 2014, 12:01 PM
Bond007's Avatar
Where are you buying from (Canada)? Those prices are high. 760 is faster and newer (660Ti is discontinued). 760 would be my pick of the two.
Newegg.ca - EVGA 02G-P4-3765-KR GeForce GTX 760 2GB 256-bit GDDR5 PCI Express 3.0 SLI Support Dual Superclocked w/ EVGA ACX Cooler Video Card
http://www.canadacomputers.com/produ...item_id=061635
Buy the MSI GeForce GTX 760 2GB GDDR5 Video Card at TigerDirect.ca
Just a quick find of multiple gtx 760 for $270-300.
Old February 28, 2014, 12:58 PM
Default Cards
These are the ones I am looking at, yes from Canada
MSI N760 GAMING GeForce GTX 760 4GB PCI-E w/ Dual DVI, HDMI, DisplayPort at Memory Express
eVGA GeForce GTX 660 Ti SuperClocked+ 3GB PCI-E w/ Dual DVI, HDMI, DisplayPort at Memory Express
Guess they are a bit more for the extra 2gb on the 760
Old March 16, 2014, 06:26 PM
aviduser's Avatar
This is probably way late, but I guess its safe to assume you have a multi monitor setup? I've picked up a 760 2gb for 260
Otherwise 4gb is useless, even at 1440p I find.
I5 4670K 4.4ghz - Gtx 780 Amp - 2x4 Corsair Vengeance - MSI z87-g43 - Tx 850w - Asus pbq278q
Old March 16, 2014, 06:45 PM
SKYMTL's Avatar
HardwareCanuck Review Editor
Neither core will be able to take advantage of the larger memory layout. They're a waste of money.
ASUS ENGTX580 DCII vs EVGA EVGA GeForce GTX 580 DS Superclocked MrSpeaker Video Cards 11 November 8, 2011 03:21 PM
EVGA Announces the EVGA GeForce GTX 580 Classified! onethreehill Video Cards 7 September 24, 2011 04:36 PM
Sli Evga GeForce GTX 570 Logger Video Cards 8 December 17, 2010 04:44 PM
EVGA Geforce GTX 470 SC+ ? Alwaysrun Video Cards 4 June 15, 2010 04:33 PM
