Old January 8, 2014, 03:10 PM
Bond007's Avatar
If the issues only started after you replaced the compound it could be an improperly seated heatsink.
Old January 8, 2014, 08:09 PM
sbohdan's Avatar
A 550Ti is not a hot card. Are you sure, the cooler is properly reinstalled on the card? Did you apply the TIM in a proper way? How is your wire management inside the case? Do you have a proper airflow (at least one fan sucking cold air in and one blowing hot air out the other side)? 85C-90C is waaay too high and you have performance issues because the card is throtleing 'cause the heat. It might be the cooler makes no proper contact with the GPU. To check this, remove the cooler, clean both the cooler and the GPU, than apply a pea-sized bit of thermal compound to the middle of the GPU, install the cooler, than remove the cooler again and check how the TIM was spread. From that you can see if the cooler makes proper contact.
Main rig: NZXT Phantom modded case watercooled, Gigabyte GA-P67-UD4-B3, 2500K@4.7Ghz,1.428V, 8GB GSkill Sniper 2133Mhz 11-11-11-30@1.6V,
Gigabyte GTX960, Acer 24" 2ms, 2xOCZ Vertex4 128GB RAID0, Samsung 2TB; PC P&C 750W, Win7 Ultimate 64
Laptop: Dell XPS 1530 (T9500; 4GB 800 RAM; 120GB Crucial SSD; 8600GT; WIN7 64bit)
my 6800LE mod
Tags
framedrop , gpu , heat , nvidia
550Ti norfolk Price Check 3 March 6, 2013 06:59 PM
How many PPD from a GTX 550Ti great_big_abyss HardwareCanucks F@H Team 8 February 24, 2012 08:32 AM
550ti Sli BF3. Pedwar Troubleshooting 4 January 22, 2012 04:29 PM
550Ti Sli? Pedwar Troubleshooting 2 January 19, 2012 10:25 PM
Am I going to be happy with 550Ti SLI? s_mack Video Cards 13 January 14, 2012 10:11 AM
