Old January 3, 2014, 08:45 AM
Coach's Avatar
ATM my 780 is using: cudaminer.exe -H 2 -i 0 -l auto,t9x16 -m 1
Old January 3, 2014, 09:28 AM
FreeKnight's Avatar
I didn't realize mining was worth anything with nvidia cards.
I've got two SLI'd 780s on a i7 [email protected] ~ 3.5ghz at the moment. If I ran all day, how much 'real' money could I make in LTC (I know it fluctuates, but a rough idea would be nice). I've never looked at mining before, but I might be tempted to give it a try if nvidia's cards work decently with cudaminer.
Thanks gents,
Old January 3, 2014, 09:54 AM
SugarJ's Avatar
Mining Litecoin would currently make you about $8 a day on 2x 780's, less power cost. 1060 kH/s Cryptocoin Mining Information, Profitability and Calculators
Old January 3, 2014, 10:06 AM
geokilla's Avatar
There's going to be a Kanye West Coin... With the recent surge of coins, keeping tabs of all these cryptocoins is a pain in the
Thanks gents,
You're better off mining the alternatives like Dogecoin or Catcoin then trading it for LTC. Catcoin is set to get a difficulty readjustment by forking.
Old January 3, 2014, 10:46 AM
FreeKnight's Avatar
Thanks for the tips guys. The Dogecoin setup looks simpler than some of the other things I looked at this morning. I think I've got a bit of a learning curve figuring out cudaminer etc, but it's worth checking out. Much appreciated.
Old January 3, 2014, 09:09 PM
geokilla's Avatar
So what coins do people have their eyes on. CoinyeWest is making itself known with other cryptocurriencies like Doge pushing it and advertising it.
Mining on any coin is the same as long as they're Scrypt based imo. All I had to do was sign up for a pool, create a worker, than change the Stratum thingy.
Old January 3, 2014, 10:45 PM
Lord_Anubis's Avatar
will this be the end of crypto currency http://bitcointalk.org/index.php?topic=396751.0 ????? Coingen Status
-Gigabyte GA-990FXA-UD7 FX-8350 @ 4.6 ghz 16gb ram Powercolor 6870x2
-MSI Z68A-GD80 I7 2600K @ 4.65ghz 16gb ram MSI R7870 Hawk
-Asrock Z77 OC Formula I7 3770 @ 4.1ghz 16gb ram Powercolor HD 7870 PCS+ MYST.(TAHITI LE)
HTPC XMBC - DFI LP UT nF4 SLI-DR X2 3800 2gb ram Gigabyte 8800 GT
Old January 3, 2014, 11:22 PM
geokilla's Avatar
Was only a matter of time... I wonder how the market will respond to this. A lot of those coins won't succeed, especially without source. And if they're terrible, then no one will mine so there's that.
  #19 (permalink)
Old January 4, 2014, 10:33 AM
sherwind2010's Avatar
Default Viper (Scrypt) Miner (5Mh/s)
It looks like Alpha Tech is taking orders again.
Viper (Scrypt) Miner (5Mh/s) Cost maybe $2,500 CAD after all said & done.
Power consumption: <= 100w
Contains one Viper board
Enclosure : 1u Rack mountable
Self contained unit with Ethernet and USB connection
Software: Easy to use configurable WebGui for mining connectivity.
Front Panel: LCD display for easy mining configuration.
Also the Viper (Scrypt) Miner (25Mh/s) for maybe $10,000 CAD all said & done.
Power consumption: <= 600w
Contains five stacked Viper boards hashing at 5 Mh/s each or higher
Enclosure : 6u Rack mountable
Self contained unit with Ethernet and USB connection.
  #20 (permalink)
Old January 4, 2014, 12:37 PM
geokilla's Avatar
Catcoin is forking. Go mine some CATS!
I thought the purpose of Scrypt mining was so that these ASIC thing can't destroy the value of cryptocurrencies...
Mining Rig! sherwind2010 Video Cards 18 February 27, 2016 07:27 PM
What is bitcoin mining??? Lucasrivers Video Cards 3 June 29, 2012 09:43 AM
Asteroid mining Deeival Off Topic 9 April 25, 2012 09:41 AM
Copper block discussion related to oxidation (NOT EK discussion or flaking) Varroa Water Cooling 8 May 31, 2011 05:20 AM
