  #91 (permalink)
Old January 29, 2014, 04:05 PM
supaflyx3's Avatar
How would you go about compiling cudaminer on windows? I'm intrigued.
With a bit of tweaking I can get my 780ti to hash at 640KH/s, can't wait to see what the new release can generate.
  #92 (permalink)
Old January 29, 2014, 07:10 PM
- Grab a .ZIP of the github from here: https://github.com/cbuchner1/CudaMiner
- Install Visual Studio 2010 or 2012 (VC++ Express 2010 or VS Express 2012 for Desktop will probably work but you'll get complaints from installer in the next step)
-- If you're using VS2012, it will ask to upgrade the C++ compilers and stuff - say yes
-- VS2013 will NOT work (CUDA complained too much for me to try it)
- Download and install CUDA toolkit https://developer.nvidia.com/cuda-downloads
-- Important the Visual Studio is installed first (or else CUDA won't be able to tell VS that it exists)
- Get the other libraries from https://bitcointalk.org/index.php?topic=167229.0
-- see the link called "cudaminer_vc2010_prerequisites.7z (49.3 MB)"
- Open the cudaminer.sln file from the contents of github zip with your Visual Studio
- Build project in release mode
- If it works, you can run the cudaminer.exe straight from wherever Visual Studio dumped it
EDIT: more Visual Studio stuff
  #93 (permalink)
Old January 30, 2014, 01:56 AM
supaflyx3's Avatar
That would be my error then, VS2013 was throwing me a bunch of errors a couple days ago and I gave up, I'll give 'er a go with 2010.
cuda installer doesnt see VS2013 or VS2010 so I'll just wait until the next release.
  #94 (permalink)
Old January 31, 2014, 01:21 AM
supaflyx3's Avatar
Left cudaminer open mining astrocoin because it was about to drop difficulty like crazy, woke up and the pool had gone down a couple times and cudaminer had moved on to my failovers.
  #95 (permalink)
Old January 31, 2014, 05:07 AM
you didn,t use an oter astro coin pool for your failover?
  #96 (permalink)
Old January 31, 2014, 05:17 AM
supaflyx3's Avatar
no I was really tired when i set it up, I still mined a decent amount so far though, the difficulty hasn't caught back up to what it was yesterday yet.
  #97 (permalink)
Old February 3, 2014, 04:09 PM
supaflyx3's Avatar
Damn the newest update of cudaminer has brought my 780ti up to 700KH/s
  #98 (permalink)
Old February 3, 2014, 04:26 PM
Nice, I will set up my 780 :)
Back up - Ebay (Inik1) or Heatware
  #99 (permalink)
Old February 3, 2014, 04:44 PM
I will try with my Titan.
Did you try turning it off and on again?
  #100 (permalink)
Old February 3, 2014, 05:16 PM
Coach's Avatar
thank you for bringing this to my attention!
Mining Rig! sherwind2010 Video Cards 18 February 27, 2016 07:27 PM
What is bitcoin mining??? Lucasrivers Video Cards 3 June 29, 2012 09:43 AM
Asteroid mining Deeival Off Topic 9 April 25, 2012 09:41 AM
Copper block discussion related to oxidation (NOT EK discussion or flaking) Varroa Water Cooling 8 May 31, 2011 05:20 AM
