Old December 21, 2013, 01:58 PM
Default Gtx 560 @ 1080p
So I'm looking at getting my self a new monitor on boxing day (Currently running a 1360x768 tv) and I can't seem to find any sort of confirmation if my gtx 560 should be sufficient for 1080p gaming or not.I know that the rest of my system is plenty enough for it (3470 and 8 gigs of ram).So ,does anyone know if my 560 is enough for 1080p or should I go with a lower resolution (I can get an ips 1600x900 monitor on sale)
Thanks for anyone who can help me out
Old December 21, 2013, 02:22 PM
supaflyx3's Avatar
No it's not, anything below a 670/760 is not enough for 1080P.
Old December 21, 2013, 02:36 PM
Bond007's Avatar
It will on med-high mixed settings for demanding games...high or better on old school/low gpu demand games. All IMO obviously. If you like all the eye candy on and high fps , then you will need something more powerful.
Edit:I posted at the same time as the other guy replied.I guess I should have stated previously ,but I am not looking to run everything at ultra with max aa,I'm just looking to get playable framerates at decent settings
Old December 23, 2013, 02:27 AM
Dzzope's Avatar
Couldn't disagree more... 560 will be enough for 90% of people that do not need / want bleeding edge graphics.
Basically half your frame-rate and thats where you'll be with 1080.. you then need to decide if it's enough.
If higher res isn't a big thing for you, the IPS x900 should look good and keep the frames higher.. That said, cheap ips for gaming isn't near as smooth as a TN panel.
Maybe get a lend of a 1080 screen from a friend and try it on the games you will be playing and then you can judge for yourself the best if it's enough.
Random quotes:
AKG: "So please don't piss on people and claim its raining. "
Soullessone21: "Their the only fat bitches I ever want in my wife :)"
DeeraxTheCoolNemo: "I never preSs CaPLoCK I just HiT my keyS so Hard ThEY Crit"
Old December 23, 2013, 04:34 AM
sf101's Avatar
2 years ago maybe .. now not really. I'm on a spare pc right now with 2500k @ 4.7ghz / 7970@ 1250/1900 and in certain games this pc even dips towards 60fps with settings up to high/ultra . this setup would smoke a 560ti / even a 448 version isnt comparable to it let alone 480/580 ect.
personally i feel 770 or 280/X minimum for today going forward unless on extreme budget restraint's that's all i could recommend with a clear conscience.
My 5 Current Rigs-Guest-Main-Work/Spare-HTPC-Laptop
I7-6700T-Work
3770K@ 4.8GHz -Main
2500k @ 4.7GHz -Guest PC
3570K @ 4.5 -HTPC
MSI GT70-2OC/770m-998/4800MHz -Laptop
SF101 HW BOT
Crossfired XFX290X@1150/1500mhz-EKWB (Main)|GIGA-OC7970WF3@1250/1850 (HTPC)
MSI 970GTX (Guest) ||Asus480GTX@900/2000 (work)
Old December 23, 2013, 05:29 PM
Well I ended up getting an hp ips 1600x900 monitor for a good price locally ,so I will give that a go ,and worse case scenario if I don't like it that much I can bring it back and grab a 1080p monitor and just dial the settings down.Thanks for everyone's help .
Old December 23, 2013, 07:12 PM
Bond007's Avatar
I honestly think you should return the monitor...My monitor is quite old now and is 1680x1050. Given the current cost of monitors I don't think there is any reason to buy less than 1080p. Personally I would rather run 1080p with some settings lowered on your GPU to make it smooth FPS, then lower the resolution.
Old December 23, 2013, 07:16 PM
It's a Christmas gift ,so I will have to wait til the 27th to return it.But in the mean while I will defiantly consider just going with 1080p
Old December 23, 2013, 08:40 PM
sf101's Avatar
oh definitly go with a 1080P as your lowest resolution but you should indeed look into replacing that videocard in the near future. dont buy a monitor with less resolution you can always run the 1080p monitor lower until you can use it at full res.
I7-6700T-Work
3770K@ 4.8GHz -Main
3570K @ 4.5 -HTPC
SF101 HW BOT
1080p LCD Monitors? nexus1111 Display Units 4 December 5, 2008 04:59 PM
1080p Phobia Troubleshooting 7 July 4, 2008 11:00 PM
