-   -   GTX 780 Max Voltage (http://www.hardwarecanucks.com/forum/video-cards/64483-gtx-780-max-voltage.html)
akirez64 December 5, 2013 11:41 AM
GTX 780 Max Voltage
I realize that this isn't set in stone, but for those of you who either overvolt with a custom bios or are familiar with people's results, what would be a safe voltage for 24/7 use? Heat will not be a factor for me.
lowfat December 5, 2013 11:44 AM
If you are watercooling it depends on your block. I assume you are using reference card? I ran @ 1.325V 24/7 for months w/ no issues. But I had fantastic VRM cooling.
akirez64 December 5, 2013 03:52 PM
I have 2 EVGA ACX SC, so yes reference PCB. My blocks are XSPC Razor.
What clocks did you hit at 1.325?
lowfat December 5, 2013 04:03 PM
1350MHz on the core.
akirez64 December 5, 2013 04:50 PM
What block were/are you using? Do you happen to know how the razor is for vrm cooling?
lowfat December 5, 2013 11:06 PM
The EK FC-Titan SE. The XSPC does pretty good @ VRM cooling as well. It should be sufficient.
Nvidia GTX780/Titan Water Block Roundup | ExtremeRigs.net | Page 9
akirez64 December 6, 2013 09:56 AM
Cheers.
