Old November 15, 2013, 11:25 AM
Originally Posted by IRQ Conflict View Post
You lost 5 FPS on the minimums. That's not a win imo. I'd want those back.
Kinda hard to replicate a benchmark on BF4 when there is no true loop, so losing 5 on minimum could have been an anomaly during testing (ie, didnt follow the exact same patch as the last test)
I have switched back to xfx bios for now, I do see some improvement but is it enough to justify possibly killing your card?
For now, I say no. But I did have fun flashing it and seeing those extra shaders and TMU's like the 290X has.
I don't mind being the guinea pig to find if it possible, but I'm not sure I want to be the one to say I killed my card.
I am curious to know if the board specs are exactly the same as the R290X (components on board)
I will say this though, the 290 is no slouch when overclocking and with steady clocks, it does keep up with his "X" brother quite well.
Intel i7 5960x @ 4.5Mhz | MSI X99S Gaming 9 ACK
32Gb G.Skill Trident RGB @3000Mhz | Asus STX audio
Gigabyte RX Vega 64 | Samsung CF791 Ultrawide 1440p (main) Yamakasi Q270 Catleap 2b @1440p (secondary)
Samsung 950 Pro m.2 @ Gen3 x4 32Gbps | Seagate 4Tb with 256 SSD cache | Corsair Obsidian 800D | Seasonic X-1250
HeatKiller 3.0 | EK RX Vega WB | TFC Exchanger Quad Rad |Thermochill PA120.3 rad|TFC Dual rad | Scythe Gentle Typhoon (x9) |Swiftech MCP655 (x2) | Koolance bay Resevior
Old November 15, 2013, 11:29 AM
IRQ Conflict's Avatar
I hear that. I wouldn't do it myself. Good call.
Old November 15, 2013, 02:44 PM
might have to buy one of these to flash it and see how long it lasts. I miss my days of frying hardware for breakfast just because....
Old November 15, 2013, 03:09 PM
SKYMTL's Avatar
HardwareCanuck Review Editor
It was on air though? Reference cooler?
Yes, reference cooler. It basically artifacted and then refused to register its display outputs. That's a dead GPU.
Remember, there's a REASON these cores have part of their SIMD arrays cut.....they didn't make the grade for the 290X.
Old November 15, 2013, 03:30 PM
"Quote This..."
Could you not just switch back to the stock Bios that disables those SIMD's?
Old November 18, 2013, 03:06 AM
sf101's Avatar
that should have been a option and then just reflash back.
otherwise the whole gpu failed which leads me to believe it was a general failure.
My 5 Current Rigs-Guest-Main-Work/Spare-HTPC-Laptop
I7-6700T-Work
3770K@ 4.8GHz -Main
2500k @ 4.7GHz -Guest PC
3570K @ 4.5 -HTPC
MSI GT70-2OC/770m-998/4800MHz -Laptop
SF101 HW BOT
Crossfired XFX290X@1150/1500mhz-EKWB (Main)|GIGA-OC7970WF3@1250/1850 (HTPC)
MSI 970GTX (Guest) ||Asus480GTX@900/2000 (work)
Old November 18, 2013, 08:48 PM
techPowerUp GPU-Z Validation 897yb
Have to do more tests but it looks like I got it to work (xfx 290). The xfx seem to have the highest success rate of these.
Old November 18, 2013, 10:53 PM
Congrats and welcome to the club
However, it seems xfx success rate is a little behind Powercolors 290. I have read one xfx fail so far and there are more powercolors that have unlocked and none that haven't. Sapphires, Gigabytes, Asus have had none unlock successfully.
  #19 (permalink)
Old November 19, 2013, 10:51 AM
To bad I am getting black screens all the time now though and found this is a common thing among 290/290x users, specifically with elpida ram (which mine has).
Might have to RMA it unless a driver patch fixes it or something. Also sent in a support ticket to see what xfx says.
  #20 (permalink)
Old November 19, 2013, 11:51 PM
AMD PR rep did post something on the forums (can't remember where) but stated their driver team is aware of the issue and is hopefully bringing out a new driver to fix this by the end of the week.
I feel for you with black screens. I remember my cold bug on my 5970 when it was watercooled. I would have to essentially put a load on the gpus to warm up before I could play any game or it would crash (grey screen). It took 6 months for a new bios from Sapphire to fix the issue as they were the only ones to admit to the issue.
R9 290x OC unveiled...? LoTech Press Releases & Tech News 0 October 20, 2013 10:46 AM
ASUS mobo flashed bios issues. Ov3rTheTop CPU's and Motherboards 2 May 8, 2012 05:25 AM
TriFire Success! Thanks HWC! Masteroderus Video Cards 5 May 5, 2012 07:57 PM
[FS] Asus X38 P5E lga775, flashed to Rampage formula Flintblade Buy/Sell & Trade 1 August 7, 2010 10:36 PM
e5200 OC SUCCESS!! Bucklaz Overclocking, Tweaking and Benchmarking 29 February 16, 2009 10:57 AM
