  #111 (permalink)
Old November 11, 2013, 07:08 PM
Look at how much the AMD cards brought up your minimum framerate. This is a good thing and the reason why it was perceived to be smoother on the AMD cards.
  #112 (permalink)
Old November 11, 2013, 07:29 PM
rjbarker's Avatar
ontarioti.....nice work.
I should have my 2 780Ti Cards by the end of the week. What would be a "common" Res we could do some comparisons at....I'm limited to 2560 x 1440..would be interesting as I'll be comparing the 780Ti SLi to Tri SLi 680's.....we could do a straight comparison 290X CF Watercooled vs 780Ti SLi (on Air though)....
Firestrike Extreme: 21.452
MARK 11: 32.530
  #113 (permalink)
Old November 11, 2013, 07:42 PM
Your_friendly_gamer's Avatar
Rj you gotta water cool them if you can, and let them loose
  #114 (permalink)
Old November 11, 2013, 07:53 PM
rjbarker's Avatar
^^^.....I know ;)
MARK 11: 32.530
  #115 (permalink)
Old November 11, 2013, 08:44 PM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
Originally Posted by ontariotl View Post
Waterblocks installed. Time to remove the TriSLi GTX670's
Damn! That is some sweeeeet hardware pr0n there mate! Bet that will keep those hot tamales purring along at full speed.
  #116 (permalink)
Old November 11, 2013, 10:06 PM
Absolutely! Running at 1.1Ghz with no throttle is nice. I will experiment more but I maybe at my limit on the cores since 1.15 was no go. I haven't played with the voltages yet since Afterburner still needs to update to properly support the 290 series unless I'm missing something.
Have it now on the build log
GTX670 TriSLi to R9 290 xfire watercooled
Intel i7 5960x @ 4.5Mhz | MSI X99S Gaming 9 ACK
32Gb G.Skill Trident RGB @3000Mhz | Asus STX audio
Gigabyte RX Vega 64 | Samsung CF791 Ultrawide 1440p (main) Yamakasi Q270 Catleap 2b @1440p (secondary)
Samsung 950 Pro m.2 @ Gen3 x4 32Gbps | Seagate 4Tb with 256 SSD cache | Corsair Obsidian 800D | Seasonic X-1250
HeatKiller 3.0 | EK RX Vega WB | TFC Exchanger Quad Rad |Thermochill PA120.3 rad|TFC Dual rad | Scythe Gentle Typhoon (x9) |Swiftech MCP655 (x2) | Koolance bay Resevior
  #117 (permalink)
Old November 14, 2013, 07:17 PM
Is there any R9 290 manufacturer that offers the card with stock cooling decent enough for the card to be used stock without getting my neighbors to complain about the noise nor built-in egg frying capabilities?
Slight exaggeration of course. I dont wanna/cant build a watercooling setup, but I love the price point and capabilities of this card. Its just screaming loud or 95C, neither of which I'm really comfortable with, you know? My last card that pushed that high partially melted my old sound card :p Not looking at SLI use. Just want to know if any of the offerings will keep the card below 90 (ideally 85) at reasonable fan speeds and noise levels?
Edit: I think I found my answer and we'll have to wait for 2014 to see any card offered with non-reference cooling.
  #118 (permalink)
Old November 14, 2013, 08:23 PM
Ya, if you wait I am sure their partners will release new non reference design boards with much better cooling. I just ordered the xfx one and plan on watercooling it, just not sure if I want to spend a little bit extra to get the aqua computer waterblock since that one looks the best out of the bunch.
AMD Radeon RAMDisk Review Comment Thread SKYMTL Storage 29 January 15, 2014 04:19 PM
AMD Radeon HD 7790 Review Comment Thread SKYMTL Video Cards 14 April 7, 2013 08:20 AM
AMD Radeon HD 6950 1GB Review Comment Thread SKYMTL Video Cards 17 January 31, 2011 05:14 PM
ASUS Radeon HD 5870 1GB V2 Review Comment Thread SKYMTL Video Cards 27 May 26, 2010 09:46 AM
Comment Thread for HIS Radeon HD3870 Review SKYMTL Video Cards 183 December 3, 2009 07:33 PM
