Old November 2, 2013, 10:04 PM
Birk's Avatar
Default Excessive TIM on GPU
Geez, So I just took the stock cooler off one of my Asus 7970 DCII cards and there was an incredible pile of TIM on the GPU, so much so that it's ground into the components directly beside the GPU die. What a friggin mess.
Is it safe to use TIM cleaner like the stuff from Arctic Silver on those parts to get it out of there?
Old November 2, 2013, 10:09 PM
lowfat's Avatar
I just clean it gentle w/ a q-tip & a bit of rubbing alcohol.
Mael
Big Lian Li
Forever Alone
Old November 3, 2013, 02:11 AM
IRQ Conflict's Avatar
Soft toothbrush.
Old November 3, 2013, 07:42 AM
LoTech's Avatar
There are different types of alcohol sold. For electronics, you want no residue left on whatever you are cleaning. I would go to your local drug store and get/ask for isopropanol 99% alcohol. Its rather cheap to buy and leaves no residue. Some that are sold have different %'s on the label so be careful.
Having said that I am not sure how to actually clean that mess. I know on heat sinks I use a coffee filter or similar type material as you do not want to leave any residue that may make the surface bumpy. But seeing all those other electronic connections in the mess, I can't actually help you there.
Maybe best to have an actual tech member chime in here. You certainly do not want to ruin or void a warranty with your card. Good luck
p://www.hardfolding.com/fhtag.php/mem/7984290/26/1.png[/IMG][/url]
Old November 3, 2013, 08:28 AM
iso from london drugs or another pharmacy. Be careful it's not the 70% stuff ya want 99%. And a soft toothbrush with some cuetips. Take your time don't rush.
Mah Rig now
Mah Rig before
My stuff for sale.
Old November 3, 2013, 11:45 AM
It's really hard to find the 99% in edmonton. Apparently it can be used to make something illegal, thus it is not for sale at memx.
Hurray nanny state!
Old November 3, 2013, 12:14 PM
LoTech's Avatar
Hurray nanny state!
Just go to local drug store. I doubt a computer shop would carry it. You may have to ask for it. In my area its not behind the counter at Rexall. I suspect you may also be able to get it at shoppers drug mart and safeway pharmacy. Also here and cheaper than what I paid.
Rougier Isopropanol 99% Isopropyl Alcohol - 500ml - London Drugs
Old November 3, 2013, 12:19 PM
sswilson's Avatar
Yeah, you usually have to ask for it from behind the counter. As far as what to use on top of the 99% alcohol, any kind of fairly fine bristle brush will do the trick, and I personally avoid using anything cotton batten based as I find they just tend to catch on sharp corners.
Old November 3, 2013, 01:36 PM
You're gonna have a hard time removing that gunk with alcohol. When I'm removing manufacturers' TIM that's on thick and/or around the chip, I spray a small amount of brake/carb cleaner, mineral spirits, etc. (petroleum based products--acetone works but it's highly concentrated and will eat the PCB) on some rag or paper towel, or soak a q-tip, and it breaks down the TIM nicely. I've never damaged components this way. Just don't spray it directly onto the parts and be sparing. Always use isopropyl alcohol afterwards to remove the petroleum residues.
Old November 3, 2013, 02:00 PM
sf101's Avatar
99% is safer than break-cleaner acetone can also eat away other things as well.
you can remove it all with 99% alcohol a cue tip just fill up the area and let it soak a while before scrubbing it the tim should soften.
My 5 Current Rigs-Guest-Main-Work/Spare-HTPC-Laptop
I7-6700T-Work
3770K@ 4.8GHz -Main
2500k @ 4.7GHz -Guest PC
3570K @ 4.5 -HTPC
MSI GT70-2OC/770m-998/4800MHz -Laptop
SF101 HW BOT
Crossfired XFX290X@1150/1500mhz-EKWB (Main)|GIGA-OC7970WF3@1250/1850 (HTPC)
MSI 970GTX (Guest) ||Asus480GTX@900/2000 (work)
