Old October 26, 2013, 08:52 PM
r0k0's Avatar
Default Overclocking my GTX780
so i tried overclocking my GTX780 earlier and i got them to some high clocks, only problem was 12-20 fps in BF3 and metro.....
stock BF3 all maxed out vsync to 60fps and metro at 28-40fps ish :P
used Msi afterburner to OC but put back to stock for now
Intel i7 3930K / 16GB Corsair Vengence DDR3-2400
Asus X79 Rampage Extreme Black Edition / EVGA GTX 770
Corsair 480GB SSD / 1TB WD Black
IN WIN 303 / EVGA NEX750 Gold
Old October 27, 2013, 09:47 AM
lowfat's Avatar
What clocks were you running at?
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old October 27, 2013, 12:17 PM
r0k0's Avatar
From msi afterburner, 187mhz extra on core / 246mhz extra on memory
So 1188mhz core / 2377mhz shader / 3250mhz memory
Old October 27, 2013, 12:30 PM
Dzzope's Avatar
Try pull em back a bit.. I'm running stable and good performance @ +168 and 145 on core and memory respectively..
Think your probably just pushing them that lil bit too far... Ohh and remember to max out the power limit and voltage in afterburner too
Random quotes:
AKG: "So please don't piss on people and claim its raining. "
Soullessone21: "Their the only fat bitches I ever want in my wife :)"
DeeraxTheCoolNemo: "I never preSs CaPLoCK I just HiT my keyS so Hard ThEY Crit"
Old October 27, 2013, 03:52 PM
r0k0's Avatar
i did pull them back, i tried playing BF3 / Assasin creed 3 and ran between 20-30fps and when on stock clocks, Vsync on 60fps and never drops below
Old October 29, 2013, 11:08 PM
r0k0's Avatar
so i tried 80mhz on core and 100 on mem, seems good in BF4 but fps are still low :(
barely running on the 30's with performance scaling at 200% and MSAA @ 0 !!
performance scaling at 125% MSAA @ 2x i get 40-50fps
and also i notice this in Kombustor, Core mhz is playing a bit, any ideas why so much play ? why not stay at the max Mhz like previous cards
GTX 780 Msi Kombustor - YouTube
Old October 29, 2013, 11:56 PM
r0k0's Avatar
got it running at 1071mhz on core and 6220mhz on memory for now, seems to be running fine and more stable Auto volts currently @ 1.137v, refence cooler @ 80% fan for 75 degres... what do you guys think ? also i clocked my computer memory back to Auto mode so its set to 1333mhz and computer has gotten me alot better performance
when i had low FPS i was running my Trident X 2400mhz @ 2400mhz... now at 1333mhz... lol
Old October 30, 2013, 04:09 AM
sf101's Avatar
if its not setting your timings properly @ 2400mhz it could actually perform slower.
but im not sure whats going on here. if it was in front of me id probably be able to figure out the problem.
make sure the in msi-afterburner the power limit is maxed out or it will restrict the card. try bumping your core volts more when overclocking. watch for throttling temps. try ocing without changing the memory clocks and see if that changes what it does.
i had a pair of 260 core 216s that would throttle if i oced the mem on them but i could oc the core to the moon.
My 5 Current Rigs-Guest-Main-Work/Spare-HTPC-Laptop
I7-6700T-Work
3770K@ 4.8GHz -Main
2500k @ 4.7GHz -Guest PC
3570K @ 4.5 -HTPC
MSI GT70-2OC/770m-998/4800MHz -Laptop
SF101 HW BOT
Crossfired XFX290X@1150/1500mhz-EKWB (Main)|GIGA-OC7970WF3@1250/1850 (HTPC)
MSI 970GTX (Guest) ||Asus480GTX@900/2000 (work)
Old October 30, 2013, 03:38 PM
r0k0's Avatar
To be honest i've never ever played with memeory speeds, only cpu overclocking,, but my ram has 2 XMP profiles and both ran the same i think, when i was stock with turbo @ 3.8ghz stock i ran 3d mark and in fire strike i got 5530, when lowfat had over 10000 with same cpu / gpu but both oced cpu to 4.4 i think and gpu i forgot but higher than what i mentionned my first post
Old October 30, 2013, 03:43 PM
lowfat's Avatar
I have my card running @ 1372/3200MHz w/ 1.325V. However I am watercooled. Aircooled the card would likely fry w/ that kind of voltage.
Queen of Dreams WIP
Big Lian Li
Complete
have 7970, is it worth it to get GTX780 Coach Video Cards 10 June 18, 2013 02:26 PM
OverClocking! KSiG Video Cards 1 March 2, 2012 08:29 AM
overclocking help and some help :D? zenotix Overclocking, Tweaking and Benchmarking 0 January 22, 2012 05:01 AM
i7 970 overclocking chrisk Overclocking, Tweaking and Benchmarking 14 December 21, 2010 09:38 AM
GTX 580 overclocking ToXic Video Cards 6 December 18, 2010 01:09 PM
