Old October 30, 2013, 03:49 PM
sf101's Avatar
talking about memory clocks on the videocards when i say throttling.
when clocking Gskill Tridant X sticks to 2400mhz make sure your using the timings listed for them should be on the box and the voltage required some times i run my voltage a tad higher even they should be 1.65volts make sure your board is supplying 1.65 volts and set this stuff manually also dont leave it for your motherboard to figure out on its own.
i dont know which trident x sticks you have if you can list the model # we can help you more.
infact when asking for help its generally best to list your entire setup and what its running at.
Some tridenx runs CL10-12-12-31 1.65 Volt and some run CL9-11-11-31 1.65 Volt stock depending on the one you have. but you should be setting those Main timings manually to make sure its getting set correctly.
I never rely on the motherboard to set memory timings properly past 1600mhz .
Use the 2400mhz profile for the sub timings and then manually set the main timings and mem voltage's to make sure your getting the best out of the memory you have.
you can also try to tighten the timings on your mem if you have the CL10 ones.
My 5 Current Rigs-Guest-Main-Work/Spare-HTPC-Laptop
I7-6700T-Work
3770K@ 4.8GHz -Main
2500k @ 4.7GHz -Guest PC
3570K @ 4.5 -HTPC
MSI GT70-2OC/770m-998/4800MHz -Laptop
SF101 HW BOT
Crossfired XFX290X@1150/1500mhz-EKWB (Main)|GIGA-OC7970WF3@1250/1850 (HTPC)
MSI 970GTX (Guest) ||Asus480GTX@900/2000 (work)
Old October 30, 2013, 05:33 PM
r0k0's Avatar
packaging code is this : F3-2400C10D-8GTX
CL10-12-12-31 1.65v
thats stock i guess for 2400mhz speed, its from the packaging
Intel i7 3930K / 16GB Corsair Vengence DDR3-2400
Asus X79 Rampage Extreme Black Edition / EVGA GTX 770
Corsair 480GB SSD / 1TB WD Black
IN WIN 303 / EVGA NEX750 Gold
Old October 31, 2013, 09:03 PM
r0k0's Avatar
ever since i overclocked my gpu and cpu/ram my computer wont run 3D Mark 2013 :(
Old October 31, 2013, 09:19 PM
lowfat's Avatar
You are clocking it too high or not enough voltage. Only overclock one at a time until you get each stable @ specific clocks.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old October 31, 2013, 10:17 PM
sf101's Avatar
which is one of the very first things i said to do lol leave the ram alone and start with the core and corevoltage increases.
I7-6700T-Work
3770K@ 4.8GHz -Main
3570K @ 4.5 -HTPC
SF101 HW BOT
Old November 1, 2013, 04:48 PM
r0k0's Avatar
msi afterburner says mV for volts... whats that ? lol i'm used to vcore haha
Old November 1, 2013, 04:52 PM
lowfat's Avatar
millivolts.
1150 = 1.15V etc.
Queen of Dreams WIP
Big Lian Li
Complete
Old November 1, 2013, 07:15 PM
r0k0's Avatar
my msi does not show my actual volts, just a +0 atm or plus 1,2,3,4,etc :P
  #19 (permalink)
Old November 1, 2013, 07:34 PM
Dzzope's Avatar
max it out.. there is a silly low cap (+34mv or something) you risk nothing with such a small gain but it could provide enough to stabilize the card.
For ocing everything nvidia since the 6xx released you basically max the voltage, max the target power and then bump the memory and core.. Personally I found the best increases by doing them together.. Some advise the chip first others the memory... try each your self and see what gives the best performance bump.
Random quotes:
AKG: "So please don't piss on people and claim its raining. "
Soullessone21: "Their the only fat bitches I ever want in my wife :)"
DeeraxTheCoolNemo: "I never preSs CaPLoCK I just HiT my keyS so Hard ThEY Crit"
  #20 (permalink)
Old November 1, 2013, 07:59 PM
lowfat's Avatar
It is easy to increase voltage beyond that limit. Just be very careful. Your VRMs will get very hot once you start to crank the voltage. I don't suggest going much higher than 1.2V on air. My EK block has fantastic VRM cooling so I can actually run @ 1.319V 24/7 and it never really gets hot. Been folding for that speed pretty much 24/7 for the past 2 months w/ no problems. Details below on what to do to.
Close MSI Afterburner Beta 15/16.
Open a admin level command prompt.
Go to C:\Program Files (x86)\MSI Afterburner\
type: msiafterburner /ri3,20,99
You get a popup box w/ a bunch of random stuff. It you see the word 'invalid' anywhere then go back to the command prompt and type: msiafterburner /ri4,20,99
Now in Windows Explorer go to C:\Program Files (x86)\MSI Afterburner\Profiles\ in there there is a configuration file called something like VEN_10DE&DEV_1004&SUBSYS_104B10DE&REV_A1&BUS_1&DEV_0&FN_0. Move the config file that starts w/ VEN_10DE to your desktop (moving only required for Win 8). Edit the file.
Under settings add the following and save. Move the file back to the C:\Program Files (x86)\MSI Afterburner\Profiles\ if you moved it to the desktop.
[Settings]
VDDC_Generic_Detection=0
VDDC_NCP4206_Detection=3:20h
If you had to use the msiafterburner /ri4,20,99 eariler on from the invalid popup box then you need to add the following instead.
[Settings]
VDDC_NCP4206_Detection=4:20h
Open MSI Afterburner. Your reference GTX780 should now be able to do 1.3V. If it didn't work try deleting all the VEN_10DE configuration files. Then start over.
Thanks to skyn3t and Zawarudo @ OCN for the how to.
[Official] NVIDIA GTX 780 Owner's Club
Queen of Dreams WIP
Big Lian Li
Complete
have 7970, is it worth it to get GTX780 Coach Video Cards 10 June 18, 2013 02:26 PM
OverClocking! KSiG Video Cards 1 March 2, 2012 08:29 AM
overclocking help and some help :D? zenotix Overclocking, Tweaking and Benchmarking 0 January 22, 2012 05:01 AM
i7 970 overclocking chrisk Overclocking, Tweaking and Benchmarking 14 December 21, 2010 09:38 AM
GTX 580 overclocking ToXic Video Cards 6 December 18, 2010 01:09 PM
