  #201 (permalink)
Old November 8, 2013, 09:18 PM
10e's Avatar
10e 10e is offline
Originally Posted by great_big_abyss View Post
Has anybody on this website bought a 290X? Does anyone have first hand knowledge to apply to this?
Yes, and I haven't seen it go down to these speeds. Mind you I'm on an open air test bench....errrr .... box.
It's been between 850 and 1000 almost the whole time under gaming and/or any other stress test. The only thing I haven't done is try to overclock it. I will save that for water cooling.
Playing with fan speeds has an almost direct correlation to speeds. It's kind of funny. I started water cooling nVidia cards because they allow better and more flexible oC on water, but this card somewhat needs it.
  #202 (permalink)
Old November 9, 2013, 12:06 AM
GT7R's Avatar
Found this an interesting read; http://www.tomshardware.com/reviews/...-fix,3666.html
  #203 (permalink)
Old November 9, 2013, 05:20 AM
So I was planing on buying a 290X and water cooling it, then I read this massive thread. In the end what I understand is that 290X fan speed was to blame for poor benchmark numbers.
So if the 290X was water cooled this issue would not effect the cards performance right?
  #204 (permalink)
Old November 9, 2013, 05:52 AM
sswilson's Avatar
That seems to be the consensus.
  #205 (permalink)
Old November 9, 2013, 08:27 AM
IRQ Conflict's Avatar
Even a decent aftermarket air solution is fine. Or wait for third party vendors to start releasing cards. AMD cocked up their cooler so bad on this, even the HWC's hamster wheel could cool it better.
  #206 (permalink)
Old November 10, 2013, 07:13 AM
I don't think I can wait till vendor cards and water blocks come out. That might be as long as 4-5 months.
I'll take one for the team and buy my cards now.
  #207 (permalink)
Old November 10, 2013, 08:26 AM
You don't have to wait for third party cards. Just buy a couple of these. Toms modified an earlier model to work with it.
Just make sure the VRM's are properly cooled with it.
  #208 (permalink)
Old November 11, 2013, 05:25 PM
Much difference between this and the 280X?
  #209 (permalink)
Old November 12, 2013, 07:10 PM
LoTech's Avatar
AnandTech Portal | AMD Changes 290 Series Fan Algorithms & About That 290 Conclusion
p://www.hardfolding.com/fhtag.php/mem/7984290/26/1.png[/IMG][/url]
  #210 (permalink)
Old November 12, 2013, 07:29 PM
Huge difference, especially if you plan on watercooling, buying a board partners cooler or don't mind it sounding like a jet engine in your computer case.
GTX 660 Ti Review Comment Thread SKYMTL Video Cards 147 September 15, 2012 11:45 PM
BFG GTX 285 OCX Review Comment Thread SKYMTL Video Cards 8 January 21, 2009 02:55 PM
BFG GTX 260 Review Comment Thread SKYMTL Video Cards 33 November 15, 2008 11:26 PM
BFG GTX 280 OCX Review Comment Thread SKYMTL Video Cards 15 August 19, 2008 08:07 PM
