Old October 11, 2013, 05:02 PM
Nodscene's Avatar
Default Video card suggestions needed.
I have a client with a decent Dell XPS and the current GPU is a 560 I believe. The problem is that their kids are playing games which are causing the card to overheat (maxes out at 104c during the Heaven benchmark) and then the display goes to sleep mode due to no signal and the computer freezes. The two options are getting a card that works in the current configuration (460W PSU and 3770, nothing else power wise to speak of), or going with a new PSU and a card in the $200-$300 range (best bang for buck).
They have a 24" 1080p monitor and not entire sure which games they play but they do have a steam account if that helps.
I know the client would rather just get a GPU and be done with it so that would be the first choice but I offered to quote both options.
What would you guys do?
Thanks.
Create something idiot proof and they will make a better idiot.
_____________________________________
Intel Q6600 - Gigabyte EP35-DS4 - OCZ Reaper 4gig PC2-6400 - XFX 8800GT 512Mb Alpha Dog - AuzenTech X-Fi Prelude - Alesis M1Active MK2 - Corsair HX-620 - Silverstone Temjin TJ05B-X - Scythe Katana 2 - WD Raptor 150Gb - Seagate 7200.11 750Gb x2 - Samsung SH-S203N
Old October 11, 2013, 05:05 PM
Getting another card isn't going to help nothing. You need to get more cooling through that system pronto or EVERYTHING is going to cook.
Old October 11, 2013, 05:07 PM
Skyllz's Avatar
Thanks.
That's problem no1. Fan/coling issues? I still run a 560ti448, the Twin Frozr edition from MSI and rarely see anything above 65c last I checked. Hitting 90+ shows there is something wrong there to begin with. Performance degrades with heat for sure also.
Is smoke supposed to come out of there?
Old October 11, 2013, 06:24 PM
Delavan's Avatar
OP,
My only warning....make sure you double check all connector types you need for that XPS rig...mobo and everything...sometimes DELL uses proprietary connectors. sometimes, the MOBO power connector is weird and different on a purpose, so regular custom PSUs don't match....
Also, cooling is bad in those cases. My buddy tried to upgrade his XPS, but had several issues, then he chose to start CUSTOM from scratch...
There is MOD logs out there for some people like you who are trying to MOD an XPS...maybe that would help....
i7 4770K @ 4.0GHz / Corsair H100i / MSI Z97A Gaming 6 / 16GB Kingston Hyper X 1.5V 1600 / MSI GTX1070 FE / Samsung 850 Evo 500gb / Corsair Performance Pro 128GB SSD / Intel 520 120GB SSD / WD Black 640 GB storage / XFX 850 watts Black Edition PSU
Old October 12, 2013, 09:28 AM
MARSTG's Avatar
Go with a GPU of comparable power, but with a good cooling solution. I would look at a 7850 should be in the same power range or lower. Is difficult to add additional cooling on brand computers, maybe a fan on the side, if the side is perforated, but usually the problem is cooling and is done like that intentionally so you keep buying new stuff.
Old October 12, 2013, 09:30 AM
Nodscene's Avatar
Aren't there cards that vent out of the case? That would probably help the situation quite a bit.
Old October 12, 2013, 10:43 AM
Dzzope's Avatar
Personally I would try fix the heat issue before upgrading... open the side and point a desk fan at it (after giving everything a good clean) and see what it does then..
If it is seriously lacking cooling I would sort that first then look at upgrades if needed and, as said above, be wary of non-standard connections etc.
Random quotes:
AKG: "So please don't piss on people and claim its raining. "
Soullessone21: "Their the only fat bitches I ever want in my wife :)"
DeeraxTheCoolNemo: "I never preSs CaPLoCK I just HiT my keyS so Hard ThEY Crit"
Old October 13, 2013, 03:34 PM
le2key's Avatar
Just so that the people here can get an idea of the airflow, is your client's Dell the one in the following link (save for the 7870)? Dell XPS 8500 Review - Desktops - CNET Reviews
If you want straight up product suggestions. I'd go with a GTX 650 ti boost and a PSU of your choice maybe something like: EVGA GeForce GTX 650 Ti Boost - System Build - PCPartPicker Canada
Probably get a good 120 exhaust on the case too.
Video card recommendation needed Asad_A203 Video Cards 7 August 18, 2011 10:54 AM
Video Card Upgrade Help needed, please :) Kitty Video Cards 30 November 28, 2010 11:28 AM
video card advice needed drako Video Cards 13 July 25, 2010 11:10 AM
What kind of video card is needed for this LCD TV neurobashing Display Units 1 August 13, 2007 02:02 PM
What kind of video card is needed for this LCD TV neurobashing Video Cards 3 August 10, 2007 02:56 PM
